What size Engine and year do i really have?
Old Jul 28, 2011 | 12:24 PM
paulldove@live.'s Avatar
Car: 1982 Z28 Camaro
Engine: 305 w/ 4bbl Edelbrock
Transmission: 5 Speed (?)
Axle/Gears: ?
Good afternoon gentleman,
I recently purchased a 82 Z28 camaro about three months ago and been slowly piecing it back together. What i have learned with no absolute certainty is that the Engine has been swapped out from the original 82 305 4bbl Quadrajet. It now has i think a 84 or 86 305 with a Edelbrock 1406 carb. The previous owner thinks it is a 86 305.
My question is how can i be for certain what damn Engine is in this car?
Year? Size? So i can finish piecing it back together?
Thanks in advance!
Oh i did look at the castings markings list but it is like greek to the novice guy like me... The acronynms are greek rather...
Old Jul 28, 2011 | 12:46 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: What size Engine and year do i really have?
Take the casting marks and plug them into google. That will get you a basic idea. There behind the drivers side head on the block surface.
Casting marks are only good for telling what the block originally started out as. They won't tell you if it's been bored or etc obvouisly.
Small blocks are the same in size on the outside, so it shouldn't cause any issues with external stuff.
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What's the casting number?
Old Jul 28, 2011 | 12:55 PM
Guest
Guest
Posts: n/a
Same size, yes. But '86 was the first year for the 1-piece rear main seal, which requires a different flywheel or flexplate than pre-'86.
Old Jul 28, 2011 | 01:22 PM
Axle/Gears: ?
I Cannot see any casting numbers outside of what is stamped on the Intake manifold Stamped behind carb
(14057053)
(GM CFM)
(43)
Fireing order is stamped in front of carb
(18436572)
Outside those markings the Engine is installed and i cant see the markings behind and below the Driverside head to see any other markings.
The Transmission is a 5 speed Manual with Hydrolic clutch if that helps.
Old Jul 28, 2011 | 01:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They're a pain to see, but they're the only ones that will tell you anything.
Old Jul 28, 2011 | 03:41 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Wasn't 87 the first year for 1pc. RMS?
Old Jul 28, 2011 | 03:45 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
87 is when they changed the center 4 intake bolts.
Old Jul 28, 2011 | 04:16 PM
Guest
Guest
Posts: n/a
'87 was the first year for roller lifters.
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
knight72
Aug 10, 2015 09:32 PM
