Ramjet 350 in 91 Rs
Old Sep 1, 2011 | 11:02 AM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Ramjet 350 in 91 Rs
I am putting a ramjet 350 in my 91 RS. Only question is I know it uses it's own computer. I will be running a tremec for transmission. What if anything do I need to do with my onboard computer as it isn't used for the engine. Will it be throwing any codes or can I just unhook it.
Old Sep 1, 2011 | 05:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ECM runs the fuel pump, which you can rig up in other ways to work. It would be simpler to just leave the ECM in there - it isn't going to get in the way.
The radiator fan is run by a switch in the passenger side head - you'll need that. I believe the speedometer was run from the VSS through a buffer box, so if you leave all that in place it should be fine. If your Tremec has a speedo cable drive instead of a VSS, you'll have to get a transducer to give the speedo a signal.
Old Sep 1, 2011 | 08:36 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Re: Ramjet 350 in 91 Rs
Can you shed light on what this transducer is? Sorry to hi jack. Been searching everywhere. Thanks! !!!!
Old Sep 2, 2011 | 09:09 AM
five7kid's Avatar
They are available from summitracing.com.
Old Sep 2, 2011 | 09:22 AM
Thanks!
Old Sep 9, 2011 | 01:02 PM
jimcairns's Avatar
I am also workin on a Ram Jet 350 in my 1988 swap. How did you address the engine oil pressure - fuel pump relay?
Old Sep 9, 2011 | 08:27 PM
89RJcamaroRS's Avatar
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
if i remember correctly the ramjet computer has a fuel pump turn on wire just tie in to your existing pump relay in engine bay
Old Sep 10, 2011 | 09:04 AM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Since the ramjet has it's own computer and there are things it cant control I will also need the original computer for other things. Since the original computer is not performing all functions will it throw codes such as check engine. If it does what would be the work around?
Old Sep 12, 2011 | 11:25 AM
five7kid's Avatar
Take out the SES light bulb.
Old Sep 12, 2011 | 12:18 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
That sounds too simple
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
