swapping 89 silverado 350 in to 89 rs 305tbi
Old Sep 22, 2011 | 03:47 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Im just woundering what be good performance upgrades to increase power on this type of engine and woundering if the specs are correct 190hp about 300ft/lb
also woundering what type of gains to expect
my goal is to be around 400 to 350 hp range
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: swapping 89 silverado 350 in to 89 rs 305tbi
i believe it a L05 engine
Old Sep 22, 2011 | 05:20 PM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
To get around your goal youll need a good cam i would get a roller cam,vortec heads,vortec carb intake,might as well convert it to carb it will be more but save you a headache of tuning or buying a custom chip.You should up around 300 maybe
Old Sep 22, 2011 | 07:17 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Oh OK how much would that run
Old Sep 22, 2011 | 09:04 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Is there a kit I can by been looking at sum top end kits
Old Sep 25, 2011 | 11:39 AM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
If you want to make that power with TBI you'll need a much larger throttle body and a different Intake. You won't feel anything after 4500 with the stocker. probably put a 155lph fuel pump in. all the holes to make it an OE roller setup are cast and tapped into that block, you can pick up the parts pretty cheap and get a nice cam. The chambers on those heads are 76cc and the compression is pretty low. the vortecs will be a great way to go to make the power.
tbichips.com has a lot of good information, and he's always willing to help. and the prices are really good too. he will reburn a chip as many times as it takes to get it right. check them out first if you want to stay tbi.
Old Sep 25, 2011 | 11:52 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea I got borerd out Intake and tbi unit bored out also to 49mm going to use a tbi space and injector spacer that should improve flow greatly on top.. stock heads are being port polish gasket match that should improve flow there a little bit also have 3 in exhuast I'm also getting fuel pump and and either a ajustable fuel regulatrr ur jus uphrade the spring and im getting my chip burn ...I plan to do a cam and head swap in future but not now. Or maybe just a cam
Old Sep 25, 2011 | 01:20 PM
Car: 86 Camaro Z28
definately do the cam, heads, and an intake to match. It'll definately make a big difference. you might want to at least do new arp rod studs and pistons for the bottom end. especially if you want to spin it higher.
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
theshackle
Aug 22, 2015 06:52 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
