CAMS???
Old Apr 14, 2012 | 12:36 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
CAMS???
what cams are you small block guys running? i'm trying to get an idea for my 355 build, i want something that lopes pretty good, and still sounds good through the exhaust.
http://www.youtube.com/watch?v=9vXD6db2xPA
something like this ^^^
Old Apr 14, 2012 | 04:50 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: CAMS???
We need way more information if you expect any kind of help.
What are the specs on your motor? Stock or modified? Heads? Headers? Carbed, tpi or something else? What transmission? What rear gears? And lastly, what are your goals? Do you just want it to sound fast, or do you want it to be fast?
Old Apr 14, 2012 | 04:55 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: CAMS???
here are the plans for the engine.
350 .30 over
scat 4340 forged rotating assembly with dome pistons and i beam rods
13.7:1 compression
750 holley carb (not sure)
patriot aluminum 64cc heads
edelbrock victor jr high rise intake
MSD ignition and components.
i want it to sound like a late model through the y pipe. and yes i will be running headers on it
i'm hoping for 450 horsepower through a 6 speed, and 4.11 gears
those are the plans and goals.
Old Apr 14, 2012 | 07:14 PM
Jim85IROC's Avatar
Re: CAMS???
What patriot heads? What size ports and what size valves? That all makes a difference. Lastly, why such high compression?
Old Apr 14, 2012 | 07:18 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: CAMS???
http://www.jegs.com/i/Patriot-Perfor.../2117/10002/-1
why not?
Old Apr 15, 2012 | 07:38 AM
Jim85IROC's Avatar
Re: CAMS???
Well, I guess I'l leave cam suggestions to the racers. I have no idea how to cam a 13.7:1 350 with heads that huge. I hope you're not expecting this combo to be streetable.
Old Apr 15, 2012 | 08:40 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: CAMS???
Yea, i just took streetability into consideration,and this engine must be streetable... What would u suggest for a cam head combo?
Old Apr 15, 2012 | 09:25 AM
Jim85IROC's Avatar
Re: CAMS???
If you want this streetable, you need to have manageable compression, heads with modest port sizes, and a cam to match.
For example, a set of good quality 180-190cc heads, flat top pistons, a dual plane intake and a reasonable cam in the 225/230 range will give good drivability, good power band, and good power.
Old Apr 15, 2012 | 01:35 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: CAMS???
CAMS.... one in the engine and one in the back seat for security
Old Apr 16, 2012 | 04:01 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: CAMS???
If it were me running a nearly 14:1 compression ratio engine I would just give a call to all the companies who produce cams for SBC's and see what they say/offer you.
Old Apr 16, 2012 | 07:38 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: CAMS???
Old Apr 16, 2012 | 09:20 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: CAMS???
Originally Posted by 1nasty86
Old Apr 16, 2012 | 11:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: CAMS???
Originally Posted by 1SICK90RS
350
13.7:1 compression.
To run that CR on pump gas you are going to need a cam with a long duration which will have a MASSIVE lope so all your wishes will be solved at once
Study DCR and it's effect on how a engine runs
http://www.kennedysdynotune.com/Dyna...ion%20Tech.htm
http://members.uia.net/pkelley2/DynamicCR.html
http://www.popularhotrodding.com/tec...eze/index.html
http://www.misterfixit.com/deton.htm
Don't forget importance of Quench
http://www.camaros.net/forums/showthread.php?t=124935
http://racingarticles.com/article_racing-10.html
It will be " streetable" all right
Just don't expect too much response below about 4000 RPM with 225 heads on a little 355
and a cam needed to run that CR on pump gas will idle about 1500 RPM
Old Apr 17, 2012 | 07:14 AM
Jim85IROC's Avatar
Re: CAMS???
And pull 6" of vacuum.
Old Apr 17, 2012 | 07:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: CAMS???
This has a shot at running on E85 with some tricks but not a snowballs chance at 13.7 to 1 on 93 oct.
Looks like your street car will run on VP 110 or higher.
Those heads/that intake, i'd go with a solid roller and shoot for 7000 rpm peak power. Problem is I'm not sure your rods will like that too much. I'd run an H beam with GOOD rod bolts. Likely a cam around 255-260 deg duration at .050. 110-111 LSA Mid high .600's lift. It will lope pretty hard but still will be driveable...is just that compression is too high for pump gas.
You should destroy 450hp at the motor and likely make that at the ground.
Old Apr 17, 2012 | 07:48 AM
Jim85IROC's Avatar
Re: CAMS???
Or just get more appropriate heads and a realistic cam.
Old Apr 17, 2012 | 07:56 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: CAMS???
its not gonna be pump gas friendly, thats for sure.
i suppose if you run a BIG cam, you can bleed off some low rpm cylinder pressure because of the overlap. kinda sounds like the building of a full on race engine. for street use, id change to some flat top pistons.
Old Apr 17, 2012 | 08:03 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: CAMS???
Yeah I'd rather see flat tops in there and shoot for 11 to 1 compression or close to it and still cam it the same way...take advantage of the heads and intake. Its gonna need to spin up to make any sort of power to move the car. 355's dont make great torque, hence why most build 383's to move power band down. 4.11 gears will help but that thing may want 4.30's or 4.56's
Old Apr 17, 2012 | 09:07 AM
Jim85IROC's Avatar
Re: CAMS???
And let's not forget that if you're really going to spin the motor to 7k or 7500, that you're going to need one hell of a good valvetrain, which will likely exceed the cost of the heads.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
