4.3l swap
Old Jul 4, 2012 | 10:21 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
4.3l swap
Hi I`m new here to third gen just wanted to show every body what a 4.3l swap looks like.
Old Jul 4, 2012 | 10:40 PM
navarrat's Avatar
Car: 1990 Camaro RS
Engine: 305 L03
Transmission: 700R-4
Axle/Gears: 2.73 Posi
Re: 4.3l swap
it looks really clean, but my only question is ....Why?
Old Jul 4, 2012 | 11:37 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
The car had a 2.8l and the 4.3l was a free replacement and its different.
Old Jul 4, 2012 | 11:38 PM
navarrat's Avatar
Car: 1990 Camaro RS
Engine: 305 L03
Re: 4.3l swap
NICE!!! Can't argue with free. It really does look good brother!
Old Jul 5, 2012 | 12:32 AM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
I should have it running in the car in a couple of weeks.
Old Jul 5, 2012 | 08:09 AM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
Re: 4.3l swap
just curious, but those look like the SBC clamshells on the block.
Old Jul 5, 2012 | 10:00 AM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
Yeah they are sbc clams off a 84 Camaro. I was going to buy a set conversion mounts for a s10 It was just easier to move the mounting pads and drill some holes. I didnt want to mess with cross member or a driveshaft. Besides with engine further back I supposed have a beter handling car. Dont know if it true yet Im waiting on some parts that should be here tomorrow so I can fire it up in car.
Old Jul 5, 2012 | 03:17 PM
Car: 86 Camaro Z28
Re: 4.3l swap
makes sense. I guess I was under the impression that the conversion brackets would have put the bell housing in the same spot as the SBC. looks good, so when are you fitting the twin turbos? JK
Old Jul 5, 2012 | 03:35 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: 4.3l swap
interesting considering this is the only one iv seen (yet pondered about one years ago). my brother is wanting do this swap, so i may watch this one
Old Jul 5, 2012 | 06:02 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
I got some work done today.
Old Jul 5, 2012 | 06:11 PM
Car: 86 Camaro Z28
Re: 4.3l swap
does the hood close with that compressor all the way up there? TBI is such a nice and easy system to work with. is the engine bonew stock?
Old Jul 5, 2012 | 06:14 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
Hey guys, I`ve got 2 questions
1. Since I am running a 4l60e I ran into the speedometer problem. I`m thinking about using the Dakoda Digital cluster. Should work right ?
2. What kind headers would you recommend. I`m trying to run the exhaust in the stock location with a custom Y pipe.
Old Jul 5, 2012 | 07:11 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: 4.3l swap
Very nice. I wouldn't pay to do a 4.3 swap, but free replacement for a 2.8 sounds good. Not sure about your tech questions, hopefully someone else more experianced will be able to help you. Best of luck!
Old Jul 5, 2012 | 07:53 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 4.3l swap
Nice looking swap.
I am thinking that you can use the original speedo gears and drive from your original 700R4 and retain your original dashboard. You should be able to remove the tailshaft housing from your old and new transmissions, pull off the drive gear from the output shaft of your old one and install it on your new piece. I BELIEVE there is a vehicle speed sensor on the back of your old Camaro gauge cluster that works off of the speedo cable. I can't remember exactly. At any rate, your pcm that is running that 4L60E should be able to use the VSS signal from your original setup to run. I'm sure someone will chime in if I have that all wrong.
I think using some "hogged out" stock Vortec manifolds should get you by, but I'm not sure what vehicle application you will need to fit the crossmember. I think full size truck stuff will rub, maybe S-10 stuff will work.
Good luck!
Old Jul 5, 2012 | 07:58 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
Yeah it closes I have .5 in clearence to the closes thing the pulley. Its a freshly rebuilt stock 4.3l with exception of the ported heads, headers, and the tbi mod. I rebuilt the transmission it has 13 vane front pump, transgo shift kit, new stock torque converter.
Old Jul 5, 2012 | 08:10 PM
Car: 86 Camaro Z28
Re: 4.3l swap
just take a set for the car and cut off the primary that doesn't match up. Just kidding.
Old Jul 5, 2012 | 08:16 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
I used a 94 Chevy Astro vans oil pan it fit perfect
Old Jul 5, 2012 | 08:18 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
I used a 94 Astro`s oil pan it fit perfect.
Old Jul 5, 2012 | 08:29 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
Yeah didn`t even think about the cluster mounted vss. Is it calibrated the same?
S10, thats what I was thinking but headers. Thanks
Old Jul 8, 2012 | 10:05 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 4.3l swap
They do. I did it this way.
Old Jul 8, 2012 | 01:15 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: 4.3l swap
Even if its not the same, it will work. You can make it perfect later if you use that box from Dakota digital that lets you adjust the signal to make it exactly right. From what I have seen from PCMs, there is a fair amount of tolerance even if the speed signal is not exactly perfect.
Old Jul 11, 2012 | 11:51 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
Here is a link to a video of the car running.http://www.youtube.com/watch?v=jMGWb1LMwtQ
Old Jul 12, 2012 | 03:50 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: 4.3l swap
Good job, man! That's the first running swap I've ever seen done with that engine.
Next, we'll need to see what kind of mileage it gets!
Great job.
Old Jul 12, 2012 | 09:53 PM
n7783e's Avatar
Car: 86 Camaro
Engine: 4.3L
Transmission: 4l60e
Re: 4.3l swap
Thsnks. I can`t wait to drive it. How much fuel millage do think I will see? If i keep my foot out of it.The little 2.8 was mpfi and was getting on a good day about 25 mpg high way. The numbers for the doner Astro was I think 18 to 24 mpg but the Camaro is lighter amd has less drag because its more aerodynamic so Idont know
Old Jul 13, 2012 | 12:31 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: 4.3l swap
My V8 and V6 cars (in near stock form) all got more than 25 mpg highway under cruise conditions. The big difference was the in town driving.
I think you should still get as good or better mileage than the V8 cars, especially with the electronic transmission. Its a slight edge to maximize efficiency.
Old May 25, 2013 | 02:18 PM
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Re: 4.3l swap
The 4.3 is very interesting swap, and congrats on getting it in and running, sounds good. Now if you got your hands on the vortec mpfi manifold, you could have that turboed pretty easily.... food for thought. If I ever picked up another 3rdgen to do a swap in, it would be for a 4.3 I think.
Old May 26, 2013 | 06:18 AM
1gary's Avatar
Re: 4.3l swap
That looks like a TBI X block out of a Astro.AWD Astro's suck for gas mileage,so in your car it should be decent.And your right,the Astro's wt is 4,000 lbs or better.In late 1993 or later they came with a W Block which was a CPI.More horsey's and better gas mileage.In 1999 and beyond they came with SFI's and again better hp and mileage.After 1995 it was a OBD II,well really 1995 was a transitional yr and had a mixture of OBD II and OBD I.But in 1996 is is a solid OBD II from that point on.
Not sure how your car's computer would phase together with the Astro's.Maybe your going to find that you have to use the same Astro computer for the engine/trans management and do a conversion of the VSS to run the gauges on your car.I have seen(although right at the minute I doesn't recall who makes them)conversions to go from a cable driven speedo to electronic and the other way around.Hooks into the trans cable housing or to the E trans output.
Old May 26, 2013 | 06:30 AM
1gary's Avatar
Re: 4.3l swap
Oh yeah.We found most Astro's have a 3.42 rear end gear.We found a good all around gear that at 60 mph actually improves gas mileage in Astro's is 3.72's.It move the power curve right under or just before the 60 mph.It was a option in some of them as was posi with a G code found in the glove box or on the passenger side door pillar.Most are 7.5's as some of these cars are,so I would think it would swap over from a pick and pull Astro.Most of the cars I've seen on here are in the lower threes and that would lug the 4.3 down to eat more gas.
The nice part about the E trans is there are stand alone programers where you can on the fly adjust the shift points and how hard those shifts are.
www.TCIauto.com
Comes to mind of one company that sells them.
Old May 27, 2013 | 09:49 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: 4.3l swap
i'm all for being different and what not, but a properly built 350 will get better mileage, make more power, and run a lot smoother.
Old May 29, 2013 | 08:27 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: 4.3l swap
Obvious statement of the year right there. He said it was free though. Oh and this thread is almost a year old BTW.
Old Aug 28, 2014 | 05:07 PM
zamora's Avatar
Re: 4.3l swap
just swap the tail housing and presto you have the speedo without all that dash stuff.
that will also fix the tq arm problem.
Old Aug 28, 2014 | 05:28 PM
zamora's Avatar
Re: 4.3l swap
how did you hook up the tq arm?
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
