First time engine pull
Old Mar 30, 2013 | 10:42 AM
Wolf91j's Avatar
Car: 89 Camaro RS
Engine: 5.0L 305 TBI
Hi everyone, I have a 89 RS with a 305 that needed to be pulled and rebuilt. I pulled it last night and it was my "first" engine pull on my own. It was really overwhelming with all the wire, plugs, and hoses going every which way! Lol I guess it's just something that you learn over time.
Old Mar 30, 2013 | 10:49 AM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Re: First time engine pull
Most important thing is that you may or may not done already
dont take everything apart whenits in the engine bay
take off as little as posible like hoses, wires, fuel lines exhaust, and motor mounts lol
First timers i always see them tear the whole thing apart while its in there its twice as hard lol
Old Mar 31, 2013 | 12:45 AM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
and don't ever cut any wire harnesses.
Old Mar 31, 2013 | 12:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Oh, wiring isn't all that bad. I'm sure yours doesn't look like this:
That's my LQ4 swap into a shoebox. I practiced on a couple of '82 Berlinettas before tackling this one...
Old Mar 31, 2013 | 05:18 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Get tape and a pen and label where everything goes as you remove it.
Old Mar 31, 2013 | 06:11 PM
Wolf91j's Avatar
Car: 89 Camaro RS
@ five7: no definately not that bad lol.
Thank you everyone, it's definately a learning process... You don't learn until you try it and make mistakes.
Old Apr 7, 2013 | 06:03 PM
rraccerr's Avatar
Car: 1986 iroc-z
Engine: 305 fuel injection
Transmission: Automatic
Axle/Gears: Don't know yet
pulling engine as well
my son has a 86 iroc-z . after all the money i put into it < it all went down the drain after gas was put into the intake by the fuel regulator and the engine frooze up. we are about to pull it tonight . still have to drop drive train and transmission mounts and of course the engine mounts. ill be posting questions and updating all of you as well as seeing what @five 7 is up to. im sure ill learn from all of you thanks. vrooooooom.
Old Apr 7, 2013 | 07:17 PM
spades's Avatar
Car: '85 Z-28
Engine: 350 carb.
Axle/Gears: 3.96 I believe
THIS... this will give me nightmares for weeks.
Old Apr 8, 2013 | 05:05 PM
five7kid's Avatar
It's really very simple. Each wire goes to one thing for one purpose (although some ground and some power wires are ganged together).
No reason to make it hard...
When you're pulling a stock engine with a stock harness, each connector can only go one place. Still a good idea to tag and label things (note the masking tape labels on my harness). I would include where they're located as well as what they are (Oil pressure switch above oil filter thermal switch in passenger head, ground wire on back of passenger head, etc.).
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
