305 to 350
Old Apr 20, 2013 | 05:16 PM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Axle/Gears: stock 2:73
305 to 350
Switching from 305 to 350 with a hot cam and headers if I was to run the tbi what would need to be done to make the proper performance
Old Apr 20, 2013 | 05:39 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: 305 to 350
From my experience with tbi which isn't much, and with tpi which is a lot, its mostly the tune and injectors and if you are using the 305 heads it may choke it and check the compression on it.
Old Apr 20, 2013 | 06:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, what heads? With most factory heads, it won't take much. With good heads, you'll want some good stuff.
Might be better to ask on the TBI forum, but I'd guess a good carb intake like a Peformer RPM or Victor Jr, 454 TBI, TBI to squarebore adapter (which will likely have to have the holes opened up). And a lot of tuning.
Old Apr 21, 2013 | 07:14 AM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Re: 305 to 350
I have stock 350 heads been redone have diff springs for cam is all just was trying to wiegh the odds of using a carb or keeping what I have whatever is easeyer
Old Apr 21, 2013 | 10:03 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: 305 to 350
You need a custom prom chip to use a 350 with TBI.
Old Apr 21, 2013 | 10:50 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: 305 to 350
tbi if you arent going for performance all the way! Its cheaper to get a tune then buy a whole set up and if you ever want to change elivation you dont have to do anything! I would recommend putting different inj in it as a 350 will mmake more power but I know people on here have done it with the 305 ones.
Old Apr 21, 2013 | 06:31 PM
five7kid's Avatar
Originally Posted by hawthor
I have stock 350 heads...
Again, what heads? About 90% of stock factory 350 heads are performance junk.
The casting #'s would tell the story.
Old Apr 25, 2013 | 07:08 AM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Re: 305 to 350
3888920 is the casting # they have been all redone ported valves screw in studs guides cut for big cam i have 1.6 roller rockers comp roller cam is 224 dur 502 int 510 exh lift
Old Apr 25, 2013 | 05:41 PM
five7kid's Avatar
I'm not coming up with anything on that number. Could they be 3998920? Sometimes hard to tell the difference between 3, 8, 9 in those cast-in numbers.
For example:
From: https://www.thirdgen.org/forums/tech...251-heads.html
I'm afraid I would put them squarely in the 90% class. Especially if they are 76cc chambers.
They will have soft exhaust valves and seats unless they have been upgraded (expensive). Not good with today's unleaded gasoline.
You may get along okay with them, but I certainly wouldn't put any money in them (which is appears is too late in your case).
Old Apr 30, 2013 | 06:16 AM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Re: 305 to 350
For example:
they are 3998920
Old Apr 30, 2013 | 01:40 PM
five7kid's Avatar
I don't have specifics on those heads, but truck heads typically don't benefit from lift over .45". So, your valves will move through that last .05" of travel without any increase in flow.
What are you going to use for an intake manifold? Your stock TBI won't bolt on without modification to the center two bolt holes on each side. And, it wouldn't support a Hot Cam very well at all. An '86-earlier style carb intake will bolt up, though. You can use a TBI to carb adapter if you stick with TBI.
Old May 1, 2013 | 06:27 AM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Re: 305 to 350
they came off a chevelle my buddy had them all redone and modified put 1000$ he said they are all set up for the cam im just gonnna run an air gap mainifold with holley carb i was just wondering about the tbi how much preformace they will actually support i plan on getting a set of dart heads in the near future but gotta run theese for now till i get more $$
Old May 1, 2013 | 02:19 PM
five7kid's Avatar
That's a topic for the TBI forum. A should yield the answer.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
