Throttle Bracket
Old Jun 3, 2021 | 07:41 PM
Peter Olson's Avatar
Car: 1985 Camaro IROC-Z
Engine: 305, building a 350
Axle/Gears: No Idea
Throttle Bracket
I completed a 350 swap on my 85 IROC. I used a summit racing intake, edelbrock performer 650 cfm carb, and got rid of anything computer controlled. My question is what brackets did you guys use to properly align the throttle cable, cruise control, and tv cable? I have bought several different ones to try them out and all look like I am rigging something up from a junkyard. TIA.
pictures to follow.
Old Jun 3, 2021 | 08:26 PM
NoEmissions84TA's Avatar
Re: Throttle Bracket
https://www.thirdgen.org/forums/carb...-tv-cable.html
Old Jun 4, 2021 | 07:20 AM
Axle/Gears: No Idea
Wow. Great write up. I'm going to try to mimic what you've done on my setup. Thanks.
Old Jun 4, 2021 | 04:51 PM
You're welcome. Good luck.
Old Jun 4, 2021 | 06:33 PM
vorteciroc's Avatar
Top Answer: 1
I do not believe that there is an aftermarket bracket that is for all 3 Cables (Throttle Pedal, Cruise-Control, and Throttle-Valve/ Transmission).
I personally used a Summit-Racing branded version of this bracket in the image below:
Along with an attachment for TV-Cable type Automatic Over-Drive Transmissions (THM700-R4 and THM200-4R):
Cleotiz
Carburetors
Oct 14, 2015 01:49 PM
Confuzed1
Carburetors
Sep 30, 2011 08:18 AM
dwillis
Jan 25, 2008 12:12 AM
Comp788
Dec 23, 2007 06:56 AM
bad_ta_05
Carburetors
Apr 13, 2003 01:49 PM
