Cannot separate T5 and 305
Old Feb 18, 2022 | 03:47 PM
rearview's Avatar
Car: 1990 LS6 Camaro
Engine: LS6 with a cam basically
Axle/Gears: 4th gen 3.42 rear
I'm ready to remove my old 305 (TBI is it matters) and T5 so put i my LS1 and T56. Last night was it. I took the transmission crossmember/mount off (driveshaft and torque arm are off already), I took loose the electricals, the clutch master cylinder, and 6 bolts from the bellhousing, 3 on each side.
The T5 is sitting on a jack so it doesn't hang too low, but I CANNOT get the transmission to move. I'm pulling it back, I'm prying, nothing. Am I missing something?
Old Feb 18, 2022 | 04:20 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Cannot separate T5 and 305
Did you un-bolt the flywheel?...
Old Feb 18, 2022 | 04:33 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
The bellhousing from the engine? Or trans from the bellhousing? I find it easier to pull the bellhousing from the engine once the trans is removed from it. Otherwise it is possible the dowel pins from the engine to the bellhousing are stuck most likely.
Old Feb 18, 2022 | 04:35 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
It sounds like your input shaft is in a bind with the pilot bushing or clutch disk.
You probably need to separate the bellhousing from the transmission. 4 bolts. After doing that, it should just slide out.
how would he get to that with the trans still on? Thinking automatic or am I thinking weird and missing something?
Old Feb 18, 2022 | 05:05 PM
T.L.'s Avatar
'Guess I was thinking automatic (doh!)...
Old Feb 18, 2022 | 05:34 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Use a little heat and lube on the bellhousing around the pins. Move trans up and down to help break it free. May need a helper. As said above, it's easier to pull trans from the bell 1st.
Old Feb 18, 2022 | 05:46 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
hehe. Just make sure... make really really really sure that all the bolts are removed before you start prying!!!
Old Feb 19, 2022 | 09:18 AM
live4formula's Avatar
Car: Bright Red 1989 Firebird Formula
Engine: LB9 5.0L TPI
Transmission: MM5 5 Speed Manual
Axle/Gears: 3.45
As said above, remove the 4 bolts that bolt the transmission to the bell housing. It is much easier to remove that way. Leave the bell housing on the engine until it is out of the car.
Do you want to sell the T-5?
Old Feb 23, 2022 | 03:56 PM
rearview's Avatar
Update. I got it off.
I did end up having to remove the transmission from the bellhousing. I could NOT get the passenger side of the bellhousing off.
Once I got the transmission off, I pulled the engine and once it was all out, the bellhousing came off pretty easily.
jtwoods4
Jan 22, 2018 01:13 PM
LostX
Aug 17, 2012 12:42 PM
BlackMamba
Southern California Area
Feb 24, 2011 11:12 AM
CG_1985_Z28
Oct 31, 2007 05:13 PM
Conman
Mar 14, 2004 03:34 PM
