83’ LS swap project
Old Mar 14, 2022 | 03:57 PM
Jaredface's Avatar
83’ LS swap project
Hey guys,
All right so I’m brand new to this forum and I’d like to say hello I’ve been on forums for years with my other hobbies and DIY projects. With that being said I have scrolled through the stickies and tried to see if my specific problem has been talked about. I am wanting to LS swap my 83 Camaro backed by the 4L80e. I found that Holley makes a conversion kit with additional parts that will allow you to use a 4L 80. However the first problem that I came across is that they’re designed for 84 through 92, and as previously stated I have an 83. The car is equipped with the LG4 305 and the 700r4. I spoke with hawke motorsports and he informed me that the transmission tunneling is different in my 83 even though it has a powertrain package that was carried on throughout the years. He continued to say that on the transmission crossmember only one of the two bolts will line up and I would have to drill and make my own, if that is the only issue then that’s ok, I will drill a hole and use a rivet nut to secure. This also makes me wonder if I will have issues with the driveshaft fitting into the transmission as well.
If anybody can guide me to threads that I may have missed that already talks about this issue I would appreciate it or if anybody can chime in I will appreciate that as well!
Old Mar 14, 2022 | 07:46 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: 83’ LS swap project
Looks good. It's not 83 feet long though...
Old Mar 15, 2022 | 01:10 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Looks like a pretty darn nice car in the picture.
Old Mar 15, 2022 | 07:29 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I'd trust hawks on this. They swap these cars on the daily. As with any LS Swap, you'll eventually have to "figure" out something that everyone else makes seem to easy. I doubt you'll have driveshaft issues. Holley kit moves the engine and trans rearward a half inch, but you should be ok.
Old Mar 15, 2022 | 12:01 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
It's as if the picture was taken in October 1983. My '84 never looked as good.
Old Mar 15, 2022 | 03:52 PM
Jaredface's Avatar
pic was taken just a couple weeks ago. She is in almost showroom new condition. 44k on her, matching numbers all stock.
Old Mar 15, 2022 | 08:56 PM
That car looks just like my little bro's 84 LG4/700-R4 car.
That said, in 83, they changed over from the "early" crossmember mounting where it was farther forward, to the "late" 84-92 setup. Some 83s have the later setup (mine does for example; T-5 or 700 cars will have it), some don't (if it came with a 4-speed or a 200C, it might not). It's not that hard to add the extra rearward nut, in any case. Probably the best way all-around is to hole-saw through the floor pan from the inside, and weld a nut inside the "frame", and use a plastic hole plug to fill the hole under the seat afterwards.
That's why Hawks doesn't claim an unconditional "fit" for 83.
Yours, being a 700-R4 car, will have the hole pattern in question, and the 84-92 kit will work as well in yours as it does in those.
Old Mar 16, 2022 | 12:57 PM
Jaredface's Avatar
Man! I appreciate your response.
Old Mar 19, 2022 | 08:47 PM
MikeP_82's Avatar
Car: 1982 Camaro Sport Coupe
Engine: 2.8
Transmission: Saginaw 4-spd
I have an 82 myself and have been researching this for a while..my info tells me if you have a t5 or 700r4 you should be ok like previously mentioned.
The drive shaft and trq arm also change lengths on the 82 and early 83's I believe.
brutforceZ28
Jul 12, 2011 01:45 PM
BIG_J_420
Mar 3, 2007 11:41 PM
82knightrider
Jan 25, 2006 08:50 PM
