92 RS 305 TBI Headers and Exhaust???
Old Dec 5, 2002 | 08:54 AM
RallyRedTexan's Avatar
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
Alright, my exhaust is pretty much completely shot, and I need to install new everything. What have you other 92 305 TBI guys done? I want a stock looking exhaust and cat, no longtubes. My car has a 2.5" dynomax exhaust designed for it, but it was cheap and I'm willing to trash it if necessary. I need to be able to bolt it up by myself without any fabrication, if possible. I think I read that you can bolt on an entire system designed for a 86-91 TPI for much better flow. Is this true? What are my options, I'm trying to keep cost down. I think I want coated headers though, they're that much better right? If possible please name names and put part numbers. I'm mostly an LS1 guy so I don't know much about my 92.
Thanks for all your help and expertise,
Robert
Old Dec 5, 2002 | 11:48 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Well, I'd say Hooker 2055s into a Catco 3'' in/out cat, into maybe a 3'' dynomax cat-back, or maybe Hooker while leaving the tips off.
The coated Hooker headers will be about $500 or so I think, 2055 is the part # .
Old Dec 5, 2002 | 12:15 PM
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
Thanks, will the install require any welding? Also, where can I find the parts for a good price?
Old Dec 5, 2002 | 01:45 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
see my sig for my exhaust set-up.
Old Dec 5, 2002 | 05:45 PM
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
JS92RS: Did you use the SLP's with AIR or without?
What part number was the Catco cat?
Is your 3" catback designed for use with a 86-91 TPI?
Was the install done by you?
Did you need to weld anything?
Thanks, sorry for the barage of questions.
Old Dec 6, 2002 | 09:39 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
w/ AIR, have to abide by the emission laws here in CA.
part # CTO-9118 from www.SummitRacing.com
Yes, part # FLO-17233 from SummitRacing.com
No
Yes
No problem, anytime.
There are other combinations out there that you can go with that would probably cost less than my set-up.
Old Dec 6, 2002 | 10:31 AM
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
Thank you very very much. I have been looking at a whole bunch of products and am now starting to get an idea of what I am going to do. I thought I would be able to do the entire install myself, but I just don't think that I will be able to do everything without welding. There are just too many variable with these cars I guess. Thanks again, your imput has been invaluble.
Old Dec 8, 2002 | 01:31 PM
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
Do any other 92 RS 5.0 TBI owners have any other suggestions or can you tell what you have done?
Old Dec 12, 2002 | 04:42 PM
JesasaurusRex's Avatar
I just bought a 3" flowmaster american thunder exaust and a dynomax high flow cat, havent gotten it yet tho, ill let ya know once its on.
Old Dec 13, 2002 | 09:48 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Mine is in my sig, and its pretty close to what Js92RS has. I have the bigger headers and no problems
Old Dec 14, 2002 | 09:28 PM
Ezey Go's Avatar
I have hooker comps (#2460).Custom y-pipe, gutted cat, and flowmaster exhaust(#17233).
Old Dec 17, 2002 | 02:35 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Im running hooker 2055s, 3" in/out Catco cat, and a Flowmaster Force II catback. I went with the single out setup because it supposedly flows better. Its quiet as hell under idle, even with the lil cam, but when you get on it you can tell its there. I dunno, I still wish it was a little louder, although that makes sneaking in at night hard
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
