Heddmans W/ O2 and no air tube???
Old Dec 18, 2002 | 07:41 PM
BikertrashDude's Avatar
Ok I put in my Hooker Cat back today and I was going to put in my heddmans headers too.
Ok I came upon a problem. my hedders have no air tube and no place for a O2 sensor.
from doing a search I have decided to put a heated O2 sensor on the Y-pipe.
what about the air tube? does one have to run from the headers? or can I do without? or do I just do more fabricating for an air tube, or get rid of the headers and go for new ones?
that would be no problem because I got the hedders for free (kind of)
well, ideas?
thanks
biker
Old Dec 19, 2002 | 08:37 PM
VampireHunterC's Avatar
Well, I have heddmen hedders with no A.I.R. provisioning, but then, all my smog stuff is LONNNG gone, so I had no problems. As far as the O2 sensor bung, I haven't gotten one yet, but I was thinking abuot welding it onto the header in front of the collector, but I don't know if the wire would reach.
Old Dec 20, 2002 | 01:15 AM
92 z28's Avatar
ok biker, get rid of your smog garbage if you can get away with emissions. delete the smog pump, smog box, pipes, air fittings and all the garbage.. #1- your engine bay will look much cleaner and more proffesion. as for the 02 sensor, buy a bung and weld it into the collector of the header... gl,
Old Dec 20, 2002 | 05:48 AM
MdFormula350's Avatar
yeah just forget about the air tubes.. and like said either weld a bung on the y-pipe or header.
Old Dec 20, 2002 | 04:22 PM
bung?
Old Dec 20, 2002 | 05:01 PM
92 z28's Avatar
its this little thing that you weld into the headers... its on jegs.
Old Dec 20, 2002 | 05:19 PM
duh....I knew what it was, just didn't know what it was called
Old Dec 20, 2002 | 07:31 PM
92 z28's Avatar
well now you know. bung bong,, same thing
gruveb
Dec 18, 2001 09:45 PM
88305tpiT/A
Sep 1, 2001 10:17 PM
vortech305
Apr 7, 2001 10:53 PM
vortech305
Mar 16, 2001 04:56 PM
88305tpiT/A
Feb 9, 2001 02:59 PM
