this is a really stupid question...
Old Apr 18, 2001 | 01:43 PM
88ta_stangkilla's Avatar
i know this is really stupid ...but what how do u gut a cat...i jus put on a 3 inch catback from flowmaster.......and i want it to be louder....
Old Apr 18, 2001 | 02:04 PM
dtpmike's Avatar
a gutted cat makes it a lot louder. Well you have to take it off first...it should jsut be bolted on although it took me forever to get it off becuase it was stuck, you jsut have to work at it and twist it. then I jsut used a rod, and a long screw driver. It takes forever to gut it and its a nasty job too. IT will be worth it though.
Old Apr 18, 2001 | 10:05 PM
86Trans Am's Avatar
if you gut your cat, wear a dust mask, dont breath the crap that comes out of there
if you gut your cat with flowmaster, there is a possiblity that it will get the hollow tinney sound
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Apr 18, 2001 | 10:24 PM
CamaroX84's Avatar
Like 86 Trans Am said, be careful when you do it. There is platinum inside that cats and when you grind on that metal, a dust will come up. So be VERY careful. Use safety equipment.
Old Apr 18, 2001 | 10:38 PM
BigMike 92 Z28's Avatar
Why gut them- I just gave the guy a 12r of Bud light and a $20 and he took them out and repiped where the cats were. I think its the way to go- It Sounds bad *** with my flowmasters ( not tiny at all ).
1992 Z28 W/5.7L. Teal with unpainted cowl hood,18" Billet Specialities Rims,Eibach Sportline Springs, Leather int., B&M Mega Shifter, Headman Headers, Flows,No Cats,K&N,HyperTech air foil,Custome Burned Chip,MSD Ignition,Shift Kit, Billet Corvett Servo my Back License plate reads "ALL UL C"
Here's a pic of my car
http://www.geocities.com/jonnyarson/maro.jpg
http://www.iroczdesigns.com/images/camgf.jpg
http://www.iroczdesigns.com/images/cam5.jpg
[This message has been edited by BigMike 92 Z28 (edited April 18, 2001).]
Old Apr 23, 2001 | 07:55 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
if its a V8 dont worry about the sound. gut the cat.
Old Apr 24, 2001 | 07:04 PM
Cam350TBI's Avatar
When I gutted my cat all I did was:
1) Unbolt the exhaust from the rear of the cat back (basically the thing you just hooked up) and let it just hang
2)Use some sort of pipe or pole (i used my floor jack pump handle...all i could find in the garage) and ram it into the cat to start breaking the material inside.
3) Crank the car up a few seconds to blow out the pieces you broke up.
4)Repeat step 2 and 3 until the cat is total free of the material inside. BE SURE TO GET IT ALL OUT, IT WILL CLOG EXHAUST IF NOT.
Hope this helps!
Old Apr 24, 2001 | 07:38 PM
Tas's Avatar
Tas
if you need to have a cat there so a cop can see it you should put a pipe through your cat. otherwise it will sound funky. like having another muffler.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
djmarch
Oct 2, 2015 10:41 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
