Please Help, TES headers in...not happy!
Old Oct 15, 2001 | 09:04 PM
chevyguy8's Avatar
I've gotten my headers in but the performance isnt there. I know this arent the best headers in the world, but they should be better than the stock manifolds, right? The engine is breathing better but it feels like the power goes out at around 5Krpms
Anybody here did other adjustments to get the full advantage of these headers?
Fuel preassure, timing, etc...
91 Camaro LO3 RS 5-spd
Open air element,
ACCEL 8mm wires w/cap n rotor,
K&N filter,
flowmaster,
TPI TES Headers and 3" I-Pipe
dual fans,
82 Glass hood w/ open vents,
removed grille,
16" Iroc-Zs,
Z28 wing
[This message has been edited by chevyguy8 (edited October 15, 2001).]
Old Oct 15, 2001 | 10:53 PM
dtpmike's Avatar
tehy are better. I noticed a difference. Your car is not going to make much power at 5k RPMs.
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock TES Headers, Exhaust cutout, Edlebrock open element, 160 degree T-stat, Hurst Dual Gate shifter, Lakeland LCA's, and a Stage 2 FastChip.
2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from http://www.MrMikes.com
Old Oct 15, 2001 | 10:54 PM
dtpmike's Avatar
what size did you get? Maybe yours are too big?
Old Oct 15, 2001 | 11:05 PM
Tas's Avatar
Tas
your cam is holding you back. Thats why the stock redline starts at 4500 RPM. The cam is tiny.
-Tas
'89 Formula WS.6
Got Beach?
Old Oct 15, 2001 | 11:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The TBI isn't going to make power past 4500 rpm probably even with headers.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 16, 2001 | 12:14 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I don't know about anyone else, but when I first put mine on, I thought it was the dumbest mistake I had ever made. After about 3-4 weeks, things got much better. I think they sometimes need a "break in" period. My buddy had the same thing happen on his truck. He didn't feel the full benefits of them until about a month after they had been on. Just give them some time, I'm sure you'll like them in the long run.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, Edelbrock Headers, Catco Cat, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, MSD 6AL, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace
Old Oct 16, 2001 | 12:59 PM
EvilCartman's Avatar
Car: '82 Z28
Could this "break in" period just be the computer adjusting to the less restrictive exhaust? When I put mine on, I noticed right away a difference.
'82 Z28
LG4 305 .030 over, performer intake, holley street avenger 670, xe 256 cam, tes headers, 3 inch single exhaust, spintech muffler, 14 x 3 inch drop base k&n.
Old Oct 17, 2001 | 08:42 PM
IROCET's Avatar
Engine: 5.7L
Well, I don't know for sure what this "break in" period is to be quite honest. I do know that I have talked to a few people that have had that happen. One guy once told me something about the metals or something...I don't know. I guess I can't really explain, I just know that it happened to me.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Old Oct 17, 2001 | 08:44 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Just another input.. on a friends 91 z28.. the same thing, about a month and the power came. On my chevelle..i installed hooker super comps with 1 5/8" primaries, noticed a huge gain right away. That computer assumption is probably correct
1972 Chevy Chevelle "Malibu"
Hooker Headers, Flowmaster 40 series mufflers, accel 8.8 wires,Edelbrock performer intake Edelbrock Carb, Torque Thrust "D" wheels
Click here for my Malibu information
In Memory of #3 Dale Earnhardt
Old Oct 18, 2001 | 09:37 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
As far as the computer is concerned, it's not a bad idea to disconect the battery during any mod. This way it resets the computer. Our computers are pretty stupid but they DO learn, a little bit. I think they kept improving OBDI from year to year until they switched to OBD2. One thing's for sure, dfferent 3rdGens respond different to similar mods.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear.
Dealer instaled:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(50), Harwood fiberglass hood.
Flowmaster 3" Cat-back exhaust,TB coolant bypass,B&M Ripper shifter, Centerforce dual friction clutch, Ported & Siamesed Plenum matched to SLP Runners, March Power/Amp Pulleys, Richmond 4.10 gears. (???HP)
Old Oct 19, 2001 | 01:44 AM
chevyguy8's Avatar
I dont know what i was thinking when i said 5k, i really just meant to emphasize the fact the power isnt there(at high rpms). i also have the 3in I-pipe and still there is something wrong for sure. Ill wait and see if this "break in period" its true, if not im still going to boost FP and mess with the timing.
By the way the headers are for a 305-350 TPI, 1 5/8s to 3in colectors.
Open air element,
K&N filter,
flowmaster,
Edel. TES Headers and 3" I-Pipe(not installed), dual fans,
removed grille,
16" Iroc-Zs,
Z28 wing
[This message has been edited by chevyguy8 (edited October 18, 2001).]
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
