Hooker 2460 vs hooker 2055
Old Dec 8, 2003 | 02:04 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
The 2460's are 1 5/8 collectors with a 3in primary, and the 2055's I cannot find a price on. The price differance is about $200, is there a big differance in the way they preform?
Old Dec 8, 2003 | 03:09 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
The 2055's have a y-pipe which is one of the best ones made. The 2460's dont have one nor is one available for them, you have to have it custom made.
As far as price, check the ad at the top out ACS coatings, you can get them coated there, and he has very good prices.
Kevin
Old Dec 10, 2003 | 02:18 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Perfoemance wise I don't think it's a big difference, but if you want a y-pipe you'll have to get the 2055's. Either that or you'll have to have an exhaust shop custom build you a y-pipe, but that's kind of hit or miss since some shops will make really crappy ones while others will make ones of similar quiality to the one for the 2055's.
Either way I would order them coated from ACS. You'll be glad you did.
Old Dec 10, 2003 | 12:48 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I love my 2055s and if I had a second chance I would have ordered them coated.
Old Dec 10, 2003 | 01:26 PM
kfoley's Avatar
Car: '85 Z28
Whatever you do, don't order them coated from Hooker. I got my 2460's coated from them and not but 8 months later all the ceramic coating came off the collectors. Definitely go with somone like Jet-Hot, ACS, or CE Coatings. Besides it will probably be less than what Hooker charges for their coating too...
Old Dec 26, 2003 | 11:12 AM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
I want to get a set of the 2055's coated for my 92 RS, but all the charts that I have seen don't seem to go up to 1992. Will these headers still fit into my car. It's a stock L03 TBI V8 motor.
I am going to get my catback at the same time, so any install suggestions would be helpful.
But my main concern is these coated 2055's fitting into my car.
Old Dec 26, 2003 | 11:31 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I got the 2460's off ebay jet hot coated for $260 with a Y pipe. The pipe is off a TPI car does anyone know if that means I should buy a TPI catback even though mine is a TBI?
Old Dec 27, 2003 | 01:34 AM
kfoley's Avatar
Car: '85 Z28
The TPI catback would most likely be larger diameter tubing, which in that cas you should get it. However I'm not sure if there's a difference between the two or not...
Old Dec 27, 2003 | 05:48 AM
Engine: 5.0L TPI
Axle/Gears: 3.08
any thoughts on my question guys?
Old Dec 27, 2003 | 01:00 PM
25THRSS's Avatar
yes the 2055's will fit your 92 as well as the tpi fitting the tbi. Do not get anything made specifically for tbi cars as they are all made to hook up to your stock 2 1/4 system.
Old Jan 1, 2004 | 02:34 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
If I buy a Hooker TPI catback and a 3" direct fit cat, will it connect directly to my factory y-pipe? I plan on getting the Hooker 2055s in the future, but i cant do it right now... any help is greatly appreciated!
Old Jan 2, 2004 | 02:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, it won't fit directly to your factory LO3 y-pipe. But, you can have an adapter fabricated to fit it until you get the headers.
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
