plug access with hooker 2055
Old Jan 17, 2005 | 12:00 PM
ar_mcadams's Avatar
Car: 91 camaro
Transmission: auto 700r4
before I order them I wanted to ask about changing sparkplugs with a set of hooker 2055 hedders. Can you get to them to change or check them without taking off the hedders. thanks
Old Jan 17, 2005 | 09:53 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Yes you can, I just did all mine. I had to grind down a spark plug socket and use a ratcheting wrench, but it wasn't bad at all.
Old Jan 17, 2005 | 10:10 PM
ar_mcadams's Avatar
Car: 91 camaro
thanks. thats what I was wondering.
Old Jan 18, 2005 | 06:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It isn't to bad. All plug to header access is made simple with one of these jobbys. You can make one of your own or be lazy like me and get one off ebay for $9.
Old Jan 18, 2005 | 09:23 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Yep, thats about the size I cut mine down to. A ratcheting wrench made it even easier.
Old Jan 20, 2005 | 12:30 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Changing the plugs if you have headers is a lot easier than changing them with the stock manifolds. #8 is still a pain though Just get/make the special socket and you will be set.
Old Jan 23, 2005 | 06:13 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
I use a crook necked wrench it worked fine for me.
Old Jan 23, 2005 | 07:11 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
One of the things I did was take a spark plug socket and take out one section of it. I cut down one flat spots and not can put the socket in from an angle.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
Glowsock
Sep 5, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
