Headers for 305?
Old Oct 14, 2005 | 08:35 PM
89Formula3's Avatar
Car: 91 Firebird
Transmission: 5 speed
Headers for 305?
What are the best headers for an 89 firebird 305(LO3)?
Old Oct 14, 2005 | 08:51 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
edelbrock TES.
Old Oct 14, 2005 | 09:56 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Originally posted by Dialed_In
edelbrock TES.
Just got a set in today (oredered before my Edelbrock ban, to good a buy at $330.00 to walk from) and will install this weekend on my '89 LO3. I'll post results.
Old Oct 14, 2005 | 10:50 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
ive heard to many bad reviews that the pipe by the primary is very crushed and restricted....i think i will be goin w/ the headman lts myself my main concern is sheilding my almost brand new msd super conductors for a decent price.
Old Oct 15, 2005 | 08:52 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Well, I started my swap this afternoon and have the d/s header on already. I'm running MSD 8.8 S/C wires as well and the boots seem to have plenty of clearance so far and this side looks tighter for wires than the P/S. Tomorrow I'll get that last #@%&* rear bolt out of the P/S and I'll post my results and opinion (if anyone's interested). So far I've been blessed with no rust, no broken studs, the dipstick tube came out fine, didn't break any plugs or sensors, and I only broke 1 diverter valve so far. Once again, thank *** I'm from the south!!
Old Oct 15, 2005 | 09:11 PM
Dialed_In's Avatar
I like the Hedmans better than the edelbrocks, but I reccomended the TES because you can keep all your emissions equipment.
You guys should run your plug wires under the headers.
Old Oct 15, 2005 | 09:31 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
I bought the Edelborck ceramic coated headers and I like them. Wasn't hard to put on and the ceramic coating looks good. I had the MSD 8.8's wires, but they didn't hold up well to the header heat. I switched to the Accell extreme's and so far they are holding up.
Old Oct 15, 2005 | 11:42 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
The MSD's you had - did you run them under or over the headers? If room permits I plan on running them under. How long have you run the Accels?
Absolutely!
Any advice/tips on getting the passenger-side rear manifold bolt out?? It's the only one I'm having a hard time reaching and I'm going in from top and bottom!!
Old Oct 15, 2005 | 11:55 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
on mine, I think I used a short wrench to get in there.
Old Oct 16, 2005 | 12:10 AM
z28 NyC's Avatar
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
I have msd wires and theyre pretty close to the exhaust manifold, a friend of mine told me i should always order plugs wires for a monte carlo because they come longer what do you guys think?
Old Oct 16, 2005 | 08:13 AM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Do you have stock manifolds or headers? The MSD kit I used is the universal HEI kit and I had lots of extra lenghth to work with, however, assembling to ends is something some don't want to mess with.
Old Oct 16, 2005 | 08:42 AM
Car: 92 Z28
I was using the MSD universal kit. I ran them under and over. Just tried to get a good fit and as far away from the header as possible. But after about a 2 months I noticed cracking on some of the wires. Thats when I went to the Accell's. Havn't had any problems yet with them.
Old Oct 16, 2005 | 01:52 PM
Dialed_In's Avatar
IMO cut to fit wire sets are the only way to go. Anything thats "custom" fit is going to be too long in most cases and no matter how you route them they're going to look like ****. Nothing worse than an engine bay with the plug wires run over everything and tangled up.
These are Moroso Blue Max wires. As long as you make them the right length and loom them together they stay plenty far enough away from the headers.
Old Oct 16, 2005 | 03:24 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
hooker 2055s are nice
Old Oct 16, 2005 | 08:36 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Well, I finished the header install today.... Whew!
I thought that last rear p/s bolt was a bear to get the old manifold off with, didn't think it would be as bad with the header flanges - HAH! Also, you'd think Edelbrock would include gaskets that had slip-in hooks on the ends, but at least they are nice graphite/aluminum sandwiched pieces that look like they may hold up for a while. Overall, everything fit as promised and it's nice and tight to the chassis. Number 1 & 3 plugs are a bear to get to but they are the only hard ones. After I get the smog system tubes hooked-up tomorrow I'll fire it up with the new Edelbrock cat-back system I also installed today. I can't wait!!
Dialed - Sweet engine!! Does that air-gap fit under the stock hood?
Old Oct 16, 2005 | 08:42 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
where did you get those valve covers,those are freaking awesome.
Old Oct 16, 2005 | 11:53 PM
benscool1's Avatar
Car: 1985 Berlinetta
Engine: Carbed 305
Transmission: Built 700r4
Which headers are best for a 305 without any of the emissions equipment? Are there any clearance issues w/the full length headers?
Old Oct 21, 2005 | 07:56 PM
Parrydise7's Avatar
Re: Headers for 305?
If you are anywhere near Anaheim, California, get in touch with Dyno Don.
Old Oct 21, 2005 | 08:05 PM
Dialed_In's Avatar
They're for sale
Old Oct 22, 2005 | 03:22 AM
dude how much?
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
Wvcamaro
Sep 4, 2015 08:38 PM
theurge
Aug 21, 2015 12:46 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
