Hooker 2210 Modification-AFR Head Straight Plug
Old Dec 19, 2005 | 05:28 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
We all know that the 2210 has a problem with clearance on the # 7 plug with these headers. I was thinking about modifing that tube to extend out a liitle further maybe 1"- 2" toward the fender. I was thinking about cutting the # 7 header tube and use a J-bent 1 3/4 to extend the pipe out, so that we can use a regular plug on that cylinder. Has anyone tried or know another remedy for extending the header tube out. The shorty plug and the 90* boots burn is not a good long term solution. The best fix will be to cut the tube and use a J-bent pipe to extent the tube so that you can use whatever plug you want without the mods. BTW: I'm talking about the problem we have with AFR Heads straight plugs.
Attached Thumbnails Hooker 2210 Modification-AFR Head Straight Plug-180-2018-20gauge-20j
Old Dec 19, 2005 | 08:08 PM
EvilCartman's Avatar
Car: '82 Z28
Someone here has done it but I think he sent the header out to a shop. I plan on doing it sooner or later, just hard for me to cut into those headers right now hehe. Dimpled the hell out of that tube for now and seems to be working just fine. The boot hasn't crumbled to bits yet after driving it around probably 150 miles.
Old Dec 19, 2005 | 11:18 PM
DTL504's Avatar
Here is a few pictures of comparision of what I have in mind.
Attached Thumbnails Hooker 2210 Modification-AFR Head Straight Plug-pc190529.jpg
DTL504's Avatar
Attached Thumbnails Hooker 2210 Modification-AFR Head Straight Plug-pc190538.jpg
Old Dec 19, 2005 | 11:20 PM
DTL504's Avatar
I think with this size tube (Ceramic) is will provide enough clearance for the plugs without a shorty and burning the plugs boots.
Attached Thumbnails Hooker 2210 Modification-AFR Head Straight Plug-pc190542.jpg
Old Dec 19, 2005 | 11:32 PM
DTL504's Avatar
I think this will be sufficient tubing to complete the modification: Mandrel Bend Tubing Exhaust Tubing, 180 Degree, Mandrel J-Bend, 1 3/ 4 in. Diameter, 2 1/ 2 in. Radius, 18-Gauge, Steel, $14.95 from Summit.
Attached Thumbnails Hooker 2210 Modification-AFR Head Straight Plug-hok-12560.jpg
Old Dec 19, 2005 | 11:35 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I had to relocate the tube and I did use a short plug. No problems whatsoever. Been this way for nearly a year now.
https://www.thirdgen.org/techbb2/sho...hreadid=324034
Old Dec 19, 2005 | 11:43 PM
DTL504's Avatar
What size tube radius did you use?
If the 2 1/2 is not enough bend I can go up to 3".
Old Dec 19, 2005 | 11:54 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
The summit part# is SUM-621003. It is 2.6" radius. Worked perfect. My advice is to order 2 of these in case you mess up on one. 94-6spd
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
evilstuie
Feb 28, 2016 03:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
