SLP Headers Modded 2 3/4 Collector
Old Mar 15, 2007 | 12:26 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
This was done to see how much more hp they make and to let more air flow out. I guess it will make about 10-15 more hp with a 2 3/4 Y-pipes from the header through the cats and 3in cat-back system.
Attached Thumbnails SLP Headers Modded 2 3/4 Collector-powdered-coated-slp-1   SLP Headers Modded 2 3/4 Collector-larger-opening.jpg   SLP Headers Modded 2 3/4 Collector-changed-collector.jpg
Old Mar 15, 2007 | 03:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
how did you do it, im going to need to do mine soon
Old Mar 15, 2007 | 06:18 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Yes please give us more info.
Old Mar 15, 2007 | 06:53 PM
VincentZ28's Avatar
You cut off up to the O2 sensor nut, use a pipe spreader to enlarge the collector without splitting the metal then weld on a ball-n-socket collector in place. Of course you may have to take it to a muffler shop that will do it for you.
Old Mar 15, 2007 | 07:01 PM
LilJayV10's Avatar
Engine: 406 Roller
Is there going to be any clearance problems with the pan or the steering shaft?
Old Mar 15, 2007 | 07:10 PM
VincentZ28's Avatar
No! The lenght of the collector didn't change.
Old Mar 15, 2007 | 07:46 PM
LilJayV10's Avatar
Engine: 406 Roller
Where did you get the 2 3/4 flange at? I have seen 2.5 and 3 in. Do they make a 2 3/4 pipe? I was thinking about doing the same thing with 3in. You have pics of the y pipe?
Old Mar 15, 2007 | 09:08 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Looks like a good modification. That should add some power to the higher horsepower motors. A good muffler shop should be able to do the mod with no problems.
Old Mar 16, 2007 | 03:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
poo, i was hoping it was something painfully simple. mine are cveramic coated so cutting them is out of the question... thanks anyway
Old Mar 16, 2007 | 08:46 PM
VincentZ28's Avatar
No pics of the Y-Pipe. The Y-Pipe will be built on the car. You can buy 2 3/4 pipe and have it modified for ball-n-socket fit. And yes you could do it with 3in pipe.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
89fast5oh
Sep 8, 2015 09:55 AM
