side pipes
Old Sep 30, 2007 | 08:28 AM
draglover's Avatar
Car: 1983 camaro Z28
Engine: 383 stroker
Axle/Gears: 4:10 full disk posi
side pipes
are side pipes legal in nj? or does the exhaust have to be behind the gas tank or do the mufflers have to be in its stock place to pass visual?
Old Sep 30, 2007 | 11:16 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: side pipes
I can only speak to the Federal and CA laws, but they stipulate that the CAT CONVERTER must be the stock number and location, it says nothing about the stock muffler. Some of the states have different levels of noise that are acceptable, but none of the cops carry noise meters, so it's a stilly law. Besides, if you hear the racket that a lot of Harley's make, I think noise is not so much a problem as the speed you are going when you are making the noise.
TA
Old Sep 30, 2007 | 02:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: side pipes
how is the car registered? i would assume that by running side-pipes, the cat is gone, so no chance passing standard inspection. you can get away with a bit more with a collectors car registration/inspection, but your mileage is limited to 3000 miles a year
Old Oct 1, 2007 | 12:41 PM
draglover's Avatar
Engine: 383 stroker
Re: side pipes
no the cat stays in its stock location but the mufflers would be almost right behind the cat it will pass the emmisions i was just wondering if it would pass the visual.
Old Oct 1, 2007 | 02:30 PM
Stephen's Avatar
Car: 87 GTA
Re: side pipes
I know here in Texas, I assume it is pretty much the same anywhere...
Behind the passenger compartment, is the rule. Somehow, side pipes exiting behind the trailing end of the doors, qualify.
After all, the early Vipers had side exit exhaust, legal in all 50 states. It just exited behind the trailing end of the doors.
Old Oct 1, 2007 | 03:44 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: side pipes
Well here in Rochester NY any thing older than 26yrs old and it is emissions exempt. Thank god i only have 3 more yrs. I have a true dual exhaust to moroso spiral mufflers and it exits before the rear tire and no one would even touch my car to install that simple exhaust. I even trailered it in with no plates and registration and told the it was a drag car and they wouldnt touch it. So I dont know how they would handle sidepipes in NJ.
Old Oct 1, 2007 | 07:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: side pipes
i believe the stipulation is that the exhaust must be past the rear most functional side window.
Old Oct 1, 2007 | 08:13 PM
Stephen's Avatar
Car: 87 GTA
Re: side pipes
Same here in TX, basically. I think ours is 24 years. At 25, your free.
BUT, that doesn't mean you can toss your emissions equipment, like the cat. It still has to be there, visually, otherwise, you'll still fail the visual portion. They just won't test the emissions level output.
That means though, you can gut your cat, run a straight pipe through it! As long as the shell is there, your good!
Old Oct 1, 2007 | 08:57 PM
racerx520's Avatar
Re: side pipes
i live in nj and the basic rule is that it must be behind the last opening window...so as long as you put it in front of your back tire, you should be good...i know this because on my brothers big 4x4 truck he tried that butwas told by the dmv that it had to be behind his back sliding window
Old Oct 1, 2007 | 10:32 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
Re: side pipes
GOOD ol' NJ......hahah i hated standing in the newark or elizabeth DMV. And moving to Utah didnt get any better......here it goes by county. If u live in Salt lake county(salt lake city area) or utah county(orem and provo) u must have a CAT an it doesnt matter where your muffler exists. If u live basically anywhere west of those counties then you dont even need a cat nor a muffler. BUT the awful noise ticket police are on the prowl.
Old Oct 1, 2007 | 10:52 PM
racerx520's Avatar
Re: side pipes
in nj, even if its a punched out cat and it passes inspection...you must still have a cat, which sucks cus i have an electric cut out and i gotta take it out before inspection lol
Old Oct 2, 2007 | 02:13 PM
draglover's Avatar
Engine: 383 stroker
Re: side pipes
alright sweet so this is what i got.
cat has to be in stock location.
there has to be mufflers.
you need the air system.
and it has to be past the doors.
sweet thanks everyone.
Old Oct 2, 2007 | 02:51 PM
Stephen's Avatar
Car: 87 GTA
Re: side pipes
As far as mufflers go....TECHNICALLY, you don't HAVE to have one. There is just a db limit, at a certain distance and if your car exceeds it, ticket time.
Not that cops carry a db meter, and check. It's "up to their discretion". Not that, you convince an inspection station, or cop, otherwise, without a meter.
Now, that's here in Texas, dunno about the other 49 states. My 92 RS/ TBI 305, never got hassled, with a gutless kitty, and no muffler. Neither by cops, not the inspection station.
Old Oct 2, 2007 | 06:44 PM
draglover's Avatar
Engine: 383 stroker
Re: side pipes
i have one more question for you guys. i want to do duels threw the hole system, i know i have one cat with the tubes for the AIR but do i need the other cat to have one aswell or is just the one ok?
Old Oct 2, 2007 | 06:59 PM
Stephen's Avatar
Car: 87 GTA
Re: side pipes
One larger diameter tube (Mufflex) will outflow full-length duals. So, why bother with the headache, of full-length duals?
Old Oct 2, 2007 | 07:05 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: side pipes
It won't pass state inspection because the exhaust will basically go right into the passanger compartment with the windows down at a stop light.. I don't know if thats the exact reason but I know thats why my friends chevelle failed inspection numerous times.. he also got numerous tickets for em.. they did exist past the window by like 5 inches though.. they look pretty tacky on a third gen anyway IMHO... what kind of pipes would you be running? I can't imagine not having them scrape on the ground everytime u hit a bump or a driveway unless your car is raised up or something. Also wouldn't they melt the side ground fx, assuming your car has gfx..
Old Oct 2, 2007 | 07:34 PM
Stephen's Avatar
Car: 87 GTA
Re: side pipes
It just dawned on me...Vipers got away with it, because there is no passenger compartment space, behind the seats. Your exhaust has to exit, behind the passenger compartment. So, short of a wall behind your seats, you can't legally have side pipes or simple side exits, like Niels car.
So, side pipes are out, I guess.
Old Oct 3, 2007 | 09:11 PM
draglover's Avatar
Engine: 383 stroker
Re: side pipes
i just realized side pipes do look pretty ugly on 3rd gens haha could i get away with the pipes just turning down after the door and before the wheel?like in the middle of the car?
Old Oct 3, 2007 | 09:19 PM
Stephen's Avatar
Car: 87 GTA
Re: side pipes
Instead of full on side pipes, do Boom Tubes...
https://www.thirdgen.org/forums/exha...st-plenty.html
Old Oct 6, 2007 | 05:36 PM
draglover's Avatar
Engine: 383 stroker
Re: side pipes
thats awesome i might just go straight down thow i did manage to pick up 8 feet of 2.5 inch piping for 5 bucks at carlisle this weekend thow so i'll experiment and try some stupid ideas hah
Old Oct 9, 2007 | 11:19 PM
1991ON20's's Avatar
Re: side pipes
got a soulution......register your car in florida! they dont give a rats @ss. no inspection or sniffer.
Terrell351
Jun 13, 2021 01:13 PM
hectre13
Sep 8, 2015 03:38 PM
transaero
Aug 31, 2015 01:14 AM
chubsworth
Aug 26, 2015 02:34 AM
db057
Aug 22, 2015 08:17 PM
