Just a quick header question.
Old Feb 2, 2008 | 02:43 PM
Shadowman's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI
Axle/Gears: Stock Gears
Ok so I plan on getting some hedmen headers sometime in the spring and my question is should I get the non air tube headers or the ones with the air tubes? I dont plan on taking out my smog pump but I wont be running any cats as I reside in KY and I have no emissions inspections here. Will the air tube headers perform as well as the non air tube ones? Cheers Ryan
Old Feb 2, 2008 | 03:11 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: Just a quick header question.
if you don't have to do emissions, get the non air tube hedders and ditch the smog pump and all the rest of power robbing emissions garbage you may have on there. If you're still using your ecm then you gotta figure out what you want...performance or a factory handicapped oversized smog pump in the form of a 305tbi
Old Feb 2, 2008 | 04:20 PM
Shadowman's Avatar
Engine: 305 TBI
I just want a little more pep out of my 305 until I do an engine swap for a 350. How would I go about deleting the smog pump? Can I buy a pully for it, and if so, where? Ive seen AC delete pullies on Summit which I plan on getting sometime this spring but I haven't came across a smog delete pulley yet. And will I have to reprogram my comp if i take out the smog pump because I have no Idea how to do that.
Old Feb 3, 2008 | 08:51 PM
Shadowman's Avatar
Engine: 305 TBI
Bump....
Old Feb 3, 2008 | 09:24 PM
Jackthestripper's Avatar
https://www.thirdgen.org/serpentine
You could do that (get a different belt), or get a delete pulley.
If you don't wanna buy a delete pulley, I've heard of people gutting out the pump and using it as a pulley. Does the same job from what I hear.
Old Feb 3, 2008 | 09:42 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Just take the pump out and get a different belt. I did it on my 305 TPI and it seems to run fine. I also have the hedman hedders without AIR and no cat.
Old Feb 4, 2008 | 04:19 AM
Shadowman's Avatar
Engine: 305 TBI
The serpintine setup sounds good. Thanks for the help.
Old Feb 5, 2008 | 12:05 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
"power robbing emissions garbage" ???? hahahahahaha
Just how much power do you think a free-wheeling pulley pushing air sucks up? 1-2 at the most.
Just remember, it doesnt matter what your state checks, the emissions devices on our cars are a FEDERAL requirement, and cannot be removed on a street car. But yes, the chances of you getting caught are slim.
The AIR tubes get in the way of changing the spark plugs, but they're liveable. Besides, if I can make the power that I do, run the ET I do, get 25 MPG, and still pass CA's draconion smog test, so can you.
Old Feb 5, 2008 | 05:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Killing a myth is nearly impossible.
JamesC
Old Feb 5, 2008 | 02:20 PM
I've been telling people these kind of things for years and then they wine about not passing.
AIR pump doesn't rob HP, buy some AIR headers and a high flow cat.
z 28 jari
Sep 14, 2021 10:03 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Ian Irvine
Sep 4, 2015 08:08 AM
