header bolt keeps coming loose
Old Apr 22, 2008 | 12:13 AM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
well my header bolt on the head keeps coming loose on my car and making a nasty exhaust leak...its the last one on the passenger side and i cranked that sheet down hard and it was loose again by about 90 miles
i dont think i want to put lock tite on it cuz i dont want it to get stuck in the head...you guys got any ideas!?
Old Apr 22, 2008 | 01:22 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: header bolt keeps coming loose
locking header bolts? there a couple of different designs... one with a metal wire that holds it, one with a clip that goes over the head of the bolt, i wish we could still get the breslin locking header bolts, those are the best design with a set screw to lock them in place. i picked up some of the wire type locking header bolts from autozone for $8 bucks, spectre makes them. i never got around to putting the wires in tho, cause they have yet to come loose.
http://www.spectreperformance.com/
http://store.summitracing.com/partde...A&autoview=sku
Old Apr 23, 2008 | 12:38 AM
myTreadZz's Avatar
You have a couple of choices
1) Stage 8 locking header bolts
2) Loc-tite (as you stated)
From the people I've spoken to about using loc-tite, the general concensus is that it's not a great idea because the product is not meant to withstand such high temperatures. But the couple of people who actually tried it told me they haven't had any problems. If the loc-tite does not work, then at least you tried.
Old Apr 23, 2008 | 05:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hey, Kansas boy. Several years ago I was told that the gasket makes all the difference. I'm unsure of how true that is, but I followed the advice and have never experienced any problems, using a Fel-Pro header gasket (Jeg's p/n 375-1404).
JamesC
Old Apr 23, 2008 | 11:27 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Here ya go, here are your options other than loc-tite....
http://www.jegs.com/p/Percy%27s/981843/10002/-1/11673
http://www.jegs.com/p/Stage+8/749275/10002/-1/11673
Old Apr 23, 2008 | 01:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Correct, Loctite loses its locking properties under heat. If they stayed tight, it wasn't the Loctite doing it.
Old Apr 23, 2008 | 01:36 PM
mbolte's Avatar
Car: 1987 Camaro
Thanks for all the ideas guys, I'll definitely look into some of them!
JamesC
Ya, Kansas boy here. I've actually seen your car at a car show in Salina. Damn nice looking car!
Old Apr 23, 2008 | 02:17 PM
JamesC's Avatar
Thanks. I'm moving to Lawrence in the next month, but I hope to make the Salina show again. If you're there, please say hello.
JamesC
Old Apr 23, 2008 | 02:39 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I have the Breslins's and no problems... little less to mess with than tabs and wire, just tools to remove if needed...
Raf
Old Apr 24, 2008 | 07:34 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I'm using the ARP 12pt with safety wire. Not as cool as the breslin, but effective.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
1984HO
Mar 19, 2021 11:59 AM
Reddeath210
Oct 6, 2015 08:20 AM
Elliswon
Aug 10, 2015 12:33 PM
