difference in 5.0 and 5.7 headers?
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
like the tittle says if i buy headers now for my 305 and when i swap in my 350 will i have to buy new headers?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: difference in 5.0 and 5.7 headers?
Not if the headers you buy now are large enough to not choke a 5.7.
ok thats kinda what i thought thanks
Engine: 383 Carb
Transmission: 4L60
Yes, as long as you stay away from exotic things like raised ports.
ok thanks now shifting gears a little bit would you recomend long tube or shorteys? you seem to have a bit of knowledge on the subject
Engine: 383 Carb
Transmission: 4L60
If it's going to be street driven, long tubes aren't worth the extra trouble.
whats the extra trouble if i buy a whole new exhaust?
ok i will thanks
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
with my duals, i have no problems with clearence.it depends on how they are tucked. x pipes will yeild less ground clearence than an H-pipe. also the S-bends will have to be turned inward towards eachother.
u are however limited to what kind of mufflers u run. a thin style muffler will be best as far as mufflers go. i have dynomax bullets. loud mouths and bullets will give the best ground clearence.
Transmission: 4L80E/4L80E
I agree with Aperion. You can't "buy" an exhaust system for long tube headers. Whatever you do will have to be fabricated, and since a typical aftermarket system designed for '86-'90 TPI single cat will handle a street 350 just fine, going through the fabrication hassle (and probably expense) of long tubes isn't worth it.
Engine: 383 Carb
Transmission: 4L60
There are more hassles than just ground clearance. I have long tubes with dual exahust on my 84 because it's my track car. For anything else that was street driven I'd save a whole bunch of my time, aggravation and money, and just bolt up a good cat back with shortys.
i think i might just buy some shorties, i seen a set from summit for $90
and then invest in a nice 3" catback or something but from what ive heard shorties are not that much better then stock manifolds and honestly i find that hard to believe
Engine: 383 Carb
Transmission: 4L60
You get what you pay for with headers, as with everything else. If the $90 ones you saw were Flowtechs (or Summit's own brand, which are made by Flowtech), you're better off spending a little more money on something else. Those ones only have 1 1/2" primaries and a poor Y pipe design, which is barely adequate for a 305, let alone a 350.
Engine: 383 Carb
Transmission: 4L60
Flowtech/Summit headers are the bottom end of the scale. They're better than manifolds, but not nearly as good as more expensive headers.
A popular choice is the Hooker 2055s. About $450 gets you the Y pipe as well (keep in mind many headers don't include the Y pipe when you're comparing the price), and they'll work with all the factory emissions equipment.
Dialed_In
Aug 20, 2015 01:45 PM
i didnt think that needed to be pointed out on a car forum, so am i right to assume that the exhaust ports on all heads are identical in space between them, location etc? at least for a chevy small block
