specific cats for a dual cat set-up???
Car: 89 Formula 350 Firebird
Engine: L98 350 TPI
Transmission: stock auto
On a dual cat set-up, do you need to find cats that are specifically made for a dual cat set-up or just get 2 normal cats?? I searched around the boards and found the subject mentioned in a place or two, but the question never got really answered. I would think that you could just rig up the system with 2 normal aftermarket cats, but I don't want to make a bad assumption and find out the hard way that they won't fit.
I'm doing a lot of research and gearing up for an entirely new exhaust system ... headers, cats, and cat-back. But my 89 formula 350 has a factory dual cat set-up, which I have been told is more of a rare feature, and because of that I want to keep it as close to stock as possible with my upgrades. Plus the factory said it was good for 10 more HP, so I pretty much just want to keep it. But the dual cats make life a bit more complicated. The only header/y-pipe combo I have found that are built for dual cats is the Hedman #68491 package. The cat-back will be the Flowmaster Force II kit #17150. But that still leaves the cats themselves to figure out.
Any ideas???
Any ideas???
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: specific cats for a dual cat set-up???
Catco 4153 is a high flow dual cat setup for the dual cat 3rd gens. Comes with the stock style routing system with Y-pipe. It's $375 from Summit.....On the other hand, a Catco 9118 (single cat, what I have) is only $148 from Summit.
Dyno Don makes single and dual cat Y-pipes for his header systems.
I appreciate modifying while retaining the stock type system layout. But honestly, nobody is going to be able to see the difference in your cats unless the system is up on a hoist. I like the keep it simple aspect of the single cat system.
Engine: L98 350 TPI
I already spoke with Dyno Don. His stuff looks great, but it doesn't come with an installation kit or step-by-step instructions and this is my first header install attempt, so I really need it to be idiot-proofed.
And I hear you on the idea that no one will see my exhaust set-up unless it is on a hoist ... but hey, I will know. Plus that could spark up a debat on whether or not the dual cats is really good for more power or not.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Any 2 1/4" aftermarket cats with the air tubes on the driver's side will work. There is not a "dual-cat" specific catalytic converter you have to use. Some companies make y-pipe assemblies that come with dual-cats, but they only work with the stock manifolds, and will not work with any headers.
Engine: L98 350 TPI
But now I have another issue ... now that I can stop looking for cats specifically made for a dual cat setup, what should I be looking for in cats. I know the cat-back kit from Flowmaster has 3" piping ... so does that mean that I need to find cats that have a 3" outlet?? And I know that the headers have 2.5" collectors, so I am assuming that the y-pipe that comes with it is also 2.5" ... so does that mean I need cats that have 2.5" inlets??
Anything else I should be worrying about??
I'm not familiar with the Hedman setup, but if its y-pipe is 2.5", then yes you will want 2.5" cats. After the two cats, two more 2.5" pipes should join together into a Y that will exit as 3". That goes into your 3" Flowmaster.
Engine: L98 350 TPI
Well, from the look of the diagram of the Flowmaster setup, it looks like it already has the y-pipe included that comes out the back of each cat and then comes together. I'm not sure if that section of pipe is 2.5" or the full 3" ... or anything else for that matter. But I was looking around different threads and saw something that made a lot of sense ... using adaptors. Wow, its always the simple solutions that are the best. For the life of me that never occurred to me. Its a good thing too because I wasn't finding any cats on Summit or Jegs that had a 2.5" inlet and a 3" outlet.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Here is a system made by Magnaflow.
"Burnout91" has one of these on his car, I modded the ends to fit my headers.
It is two 2 1/2" pipes into a Y but the y cones down to fit the stock I pipe.
I cut it back to where it is 3" and connected it to the 3" I pipe.
It works well on his car.
Engine: L98 350 TPI
Plus budget is a big concern ... that is why I'm thinking Flowmaster ... a little bit cheaper and hopefully I will get the sound I am looking for. But those polished Magnaflow kits look really nice too. Do they outperform Flowmaster or sound better ... enough to justify the extra cost????
Sorry, I thought the # was there ...#23479
Their cat back is way better than Flowmaster.
Engine: L98 350 TPI
Will this fit onto headers or will it require a lot of modification??
