Header Leak
Old Nov 24, 2008 | 10:09 AM
350tpiRS's Avatar
Car: 89 Camaro RS
Engine: 350TPI
Header Leak
I just put a set of new edelbrock headers on and they have a leak. I have tightened them twice and still have a header leak. Does anyone have any suggestions? Thanks in advance
Old Nov 24, 2008 | 12:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Header Leak
Yeah, that's a problem with those.
Which gaskets are you using? You might have to use two gaskets.
Old Nov 24, 2008 | 12:46 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Header Leak
Had the same problem, just use thicker gaskets, that seems to solve the problem
Old Nov 24, 2008 | 11:36 PM
84z350crate's Avatar
Car: 84 Z28
Re: Header Leak
my edelbrocks were leaking too, mine were because the bolts came loose, I tightened the bolts and I burnt the crap out of my finger that day when I was trying to reattach my temp gauge wire- it fell off the sending unit
Old Nov 25, 2008 | 07:55 AM
350tpiRS's Avatar
Car: 89 Camaro RS
Engine: 350TPI
Re: Header Leak
Thanks guys i'll try it with two gaskets and let you know how it goes.
Old Nov 25, 2008 | 06:44 PM
Procharged GTA's Avatar
Car: 1991 Trans Am GTA Drag Radial Car
Engine: F-2 Procharged 18* 434 sbc on Alky
Transmission: Powerglide,Neal Chance Converter
Axle/Gears: Moser 9" Ford 3.50's,35 spline axle
Re: Header Leak
We use copper gaskets with the Edelbrock headers on my dads car,no leaks yet. We use copper header gaskets on almost everything.
Old Nov 25, 2008 | 09:04 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Re: Header Leak
I guess I went overkill...
I used percy's dead soft aluminum and split lock bolts... No leaks
Max,
Old Nov 25, 2008 | 09:50 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: Header Leak
Max,
dead soft aluminum will do the trick
z 28 jari
Sep 14, 2021 10:03 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
