Headman long tubes and not much clearance
Old Apr 5, 2009 | 09:57 PM
87CamaroLT43's Avatar
Car: 88 GTA, 92 Formula
Engine: 355, LB9
Transmission: WC T-5, WC T-5
Axle/Gears: 3.27 LT1 Rear
Got a 1988 Pontiac TransAm GTA... LB9 replaced with a 350.. cam, heads and intake work. But having undercar clearance problems due to the car being lowered by 3 inches in the front and 2.5 in the rear. I searched thru a little bit and seen that everyones been pointing towards the Mufflex Y-pipe but not sure if installing that will hinder my already limited clearance under the car. Anyone dealing with the same problems? Any input would be greatly appreciated
Old Apr 5, 2009 | 10:17 PM
skinny z's Avatar
Re: Headman long tubes and not much clearance
Old Apr 5, 2009 | 10:31 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
someone has not been reading up before they did a project. look on the exhaust boards and you will find hundreds of ways around your little problem.
you cant do something at least 50 people have not done before so research like crazy and save yourself a lot of problems.
Old Apr 6, 2009 | 10:29 AM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
i have some pics of mine routed. i too have hedman lt. check out the pics at https://www.thirdgen.org/forums/memb...rt-finish.html
Old Apr 7, 2009 | 06:12 PM
Engine: 355, LB9
Very nice work bro... i can't follow that routing tho. I'm still using the 700r4
Old Apr 8, 2009 | 08:29 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
While I don't have headman LT's (I have the Hookers), I still had to come up with y-pipe solution. I ended up getting a custom y-pipe made then mating it to a mufflex 4 inch cat back.
Sorry for the blurry pic.
Old Apr 8, 2009 | 05:30 PM
Demon355's Avatar
Man that looks sweet Thomas, whats the ground clearance on that? What muffler you running?
Old Apr 8, 2009 | 07:22 PM
Engine: 355, LB9
wow. Nice work... Is your car lowered?
Old Apr 9, 2009 | 02:35 PM
Car: 1986 Iroc
Engine: Afr 408
Demon - Thanks. The lowest point is where the y-pipe bends around the frame/tranny crossmember. I'm still kinda playing with my ride height in terms of springs and wheel diameter. Right now I would guess 5-6 inches? The car is actually up in the air so I can't measure it. Its a spintech muffler that comes with the mufflex system, single 4 inch in to two 3 inch out, similar to the stock setup.
87Camaro - Thanks! Well, I would say the car is sorta lowered. The front springs are the Moog Iroc springs with half a coil cut off. The rears have a half coil cut and the isolater removed (due to the 9 in. rear). I'm still playing around with things.
Old Apr 9, 2009 | 03:32 PM
skinny z's Avatar
I'm not sure if you can get tucked up any tighter than this.
The OEM crossmember has been modified to use up every inch of clearence.
Those are hedman headers and the car is lowered.
Attached Thumbnails Headman long tubes and not much clearance-pipe.jpg   Headman long tubes and not much clearance-100_1896.jpg   Headman long tubes and not much clearance-clearence.jpg
Old Apr 9, 2009 | 05:42 PM
Engine: 355, LB9
Thanx guys... i'll see what i can come up with. Probably gonna have to modify my crossmember to get the clearance.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
z 28 jari
Sep 14, 2021 10:03 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
SG91camaro
Sep 5, 2015 10:27 PM
