couple of problems with 2055's
Old Jun 26, 2009 | 11:43 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Okay, I finally finished installing my 2055's, it's just the header-y-pipe- to my cat, no muffler, yet, for maybe a week, it sounds like freakin nascar, it's so loud.
Now to the problems, it was smoking a bit, I'm pretty sure it's exhaust, it wasn't alot of smoke but you could tell it was smoking.
And I have an unplugged sensor that was routed in the same convoluted tubing as by o2 sensor, but I can't find a plug in for it anywhere, I heard it could be the temperature gauge sensor, where is that located?
You guys know how when we crank our cars all the gauges go all the way to the right of the gauge, and then drop down to their normal positions when the car starts? Well would the temperature gauge still do this if it wasn't plugged into it's connector?
Thanks to anyone that can answer
Old Jun 27, 2009 | 11:41 AM
leonpiper69's Avatar
Car: 91 mustang
Engine: ls1
Axle/Gears: 3.55 8.8
Re: couple of problems with 2055's
its probably either your temp sender or a/c high limit switch. if its the temp your looking for, thats in the haed, above the spark plugs
Old Jun 27, 2009 | 12:19 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Smoking with new headers is normal. When i cured my vht paint they smoked like a chimney for a few minutes.
Also, if the wire connector is on the drivers with the O2 it is your gauge sendor. It's on the drivers side head between the first two cylinders. In this pic it is directly left of the Hooker name badge thing on the primary.
EDIT: This pic is over 2 months old and alot has changed under the hood, looks much better today!
Old Jun 27, 2009 | 11:01 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
I think I see what the sensor is, but in connection is a circle, it's not flat and plug in like. I'll take a pic tomorrow if I can, I'm almost certain it's the temp gauge, it just lays flat at that farthest hatch mark on the left of the gauge.
Old Jun 27, 2009 | 11:53 PM
Car: 91 mustang
Engine: ls1
that's correct. the connecter just slides over the circle sideways.
Old Jun 28, 2009 | 12:04 AM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
yeah the smoke scared me too before i read that it was normal
Old Jun 28, 2009 | 03:11 AM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
Easy fix on the paint: John Deere muffler paint. Sold in silver or black, $8-12 a can (you'll need 2). Been on my headers for 6 years and no peeling. It is made specifically for mufflers.
Do these headers come with a y-pipe? I assume not since someone mentioned looking for a cheap one.
And, someone mentioned coating for $100? Where?
Thanks for the pics you posted.
Old Jun 28, 2009 | 12:28 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
It does? It looks way too small and flat, I'll check later tonight or tomorrow. Thanks
Cleotiz
Jan 6, 2018 08:56 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
