Pipe size?
Old Aug 9, 2009 | 12:54 PM
Chrome on Rust's Avatar
Car: 89 RS
Engine: 305 TBI
Pipe size?
I Have a 89 Camaro it is a 305 TBI Automatic. Im in the mittle (closer to the end now ) of changing out entire floor pans, man were they bad! This is my first project car so go easy on me... No upgrades as of now want to do a little work to the top end later on. Basicaly I am going to beef it up some. But would like to switch over to true dual exaust, first. Yea i have read, on the fourm, about how much of a (fill in the blank) it can be. But, thats the way i would really like to go. So knowing that it is going to be a semi-beefed up 305. What size pipe should I run? Ive read through and seen Wille's true dual exaust, and know that it is a Z28, but he ran 2 1/2 is that what I should run as well?
Also, we will call this question two, I never really tryed to do a search on Cats but was on fourm seaching a lot yesterday, and never got finished so i'll just ask. Want to know what kind of cat's i should be getting for this application. I see most guys not talking about them on the fourm when they tell what they have done to their exhaust but i live in IL and we have emissions (and salt). Any links to helpful sites/pics would be appreciated.
For now its back to floor pans.
Thanks,
Chrome On Rust
Old Aug 9, 2009 | 02:28 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Pipe size?
not to put you down or anything, but with a semi beefed up 305 a good set of headers and y pipe along with a 3 inch single catback will flow plenty enough for your mods. But if you want to go dual, 2.5 inch will flow plenty enough
Old Aug 9, 2009 | 03:08 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Pipe size?
Thanks,
Chrome On Rust
the only problem with duals is that there is almost no space under the car. a few days ago a member posted his way of handling it - he used some flex pipes.
and it looked pretty good.
just make sure you read a lot to make sure you know what you want.
most people use the passenger side for the pipes because that is where gm put the heat shield.
have a good time, you will love it.
Old Aug 9, 2009 | 03:53 PM
Stephen's Avatar
Car: 87 GTA
Re: Pipe size?
2.25" Dynomax, bolt on kit.....Size should be good for a 305.
https://www.thirdgen.org/forums/exha...ms-solved.html
Old Aug 9, 2009 | 07:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Pipe size?
All aftermarket Cat's are hi-flo, so really doesn't matter on a Cat - they are all the same for the most part.
Old Aug 9, 2009 | 09:36 PM
Car: 89 RS
Engine: 305 TBI
Re: Pipe size?
Anyone else think this would be the way to go?
I saw that it was 2.25 tubing and not mandrel bent. Is that going to be an issue at all, or would 2.5 mandrel bent add a noticeable diffrence?
Thanks for the help so far all.
Old Aug 9, 2009 | 10:29 PM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
Re: Pipe size?
If it was me unless less your planing on building 400 plus hp motor in the future I would put a set of good shortys and a single 3in exhaust! I have hooker 2055 and a flowmaster force2 3in and love it.. not to loud! But im in the process of putting hooker ceramic coated long tubes and 2.5 duals with a x-pipe!
Old Aug 10, 2009 | 05:56 AM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Re: Pipe size?
I agree with this guy....shorty's, and 3 inch unless you plan a bigger build later.
Old Aug 10, 2009 | 11:23 AM
Car: 1992 RS
Engine: Carbed 350
Re: Pipe size?
I have stock I-pipe (2.25 maybe?) on my 350, and I get plenty of flow - my headers reduce to match the stock cat, and I'm running an Aerochamber muffler.
Old Aug 10, 2009 | 12:27 PM
Car: 89 RS
Engine: 305 TBI
Re: Pipe size?
So there is going to be no gains beteen the true dual 2.25 over the one three inch? I mean i really would like to have duals but if it is only going to hinder my preformance then i would rather have the 3in.
Old Aug 10, 2009 | 12:38 PM
Car: 89 camaro
Engine: 383
Re: Pipe size?
with your motor now a single 3in is more than plenty! you problely wouldnt gain any power with duals ..you could go duals if you want but its going to be a hassel and loose ground cleance! I think you would be more happy with a good 3in set up!
Old Aug 20, 2009 | 04:00 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Pipe size?
3" single.
For what it's worth, after much reseach that's what I'm going with
on a pretty highly mod'd 350; Hooker shorties, Doug's (cheaper)
Y-pipe, short high-flow cat, and Dynomax cat-back muffler system,
all 3" components. Only caveat is that the y-pipe has a 2.5' collector
outlet. But I think (actually hoping at this point) that I can trim off
some of the outlet, opening it up to 3", and then weld on a 3" section.
At the risk of incurring environmentalist wrath, I won't talk about how
I intend to fab some ball-socket connectors into the system. Then I can
run a straight pipe 364 days a year, and cat section on inspection day.
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
Camaro_383
Sep 11, 2015 11:28 PM
m00n420
Sep 11, 2015 02:39 PM
