using gto headers on ls1 swap
Old Dec 2, 2010 | 07:02 PM
morbital's Avatar
Car: '89 Camaro RS
Engine: 5.7 LS1
Transmission: 6 SPD.
Axle/Gears: 3.25
i know most of you have though of using gto headers or exhaust man. out of gto's instead of a camro. but so u guys know that it does not fit. i seemd to try out the '04 gto stock headers and have problems with the collectors. these ends flare out that they are a couple of hairlines away from touching the sidewalls, the drivers side cannot be installed by moving the brake lines inward and by doing that it still almost touches the sidewalls. so those of you who thought of trying it out.. chances are you are better sticking with 02 camaro exhaust manif. since i heard they are as effective compared to shorties. but a custom exhause is recomemded (of course) by stainless works. i dunno if corvette headers work. but im sure the info is out there!
Old Dec 5, 2010 | 07:06 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: using gto headers on ls1 swap
Corvette stuff doesn't work.
Old Dec 6, 2010 | 05:00 PM
Pocket's Avatar
Car: 91 Trans Am
LS1 Fbody, GTO, C5, LSx truck all dont fit at all
2010 Camaro shorties fit, mids are still a maybe, LTs drag the ground
To date your choices: 98-02 Fbody manifolds, 98-02 shorties, SSW/Hawks LTs, BRP mids/LTs
Old Dec 6, 2010 | 09:10 PM
morbital's Avatar
Car: '89 Camaro RS
Engine: 5.7 LS1
Axle/Gears: 3.25
wow even 2010 camaro shorties work? man.. i looked at the X pipe on that year and is pretty tight and might look like it would work
Old Dec 6, 2010 | 09:17 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
wait a min, so something like these work as well Pocket?
http://www.jegs.com/i/Edelbrock/350/65172/10002/-1
Old Dec 6, 2010 | 10:58 PM
Pocket's Avatar
Car: 91 Trans Am
They look like it. The 1.625" primaries is killer though
Old Dec 8, 2010 | 01:30 PM
morbital's Avatar
Car: '89 Camaro RS
Engine: 5.7 LS1
Axle/Gears: 3.25
watch out for those 3 inch collectors!! i heard that if u were to lower your car with a collector that big.. expect clearance issues.. but then again im talking about LT headers.. i wonder how nicely they will fit on our thirdgens..
Old Jan 19, 2015 | 09:00 PM
TexasTerror's Avatar
Car: 1985 IROC-Z28
Engine: 6.0l lq4
Transmission: FTI TH400
Axle/Gears: 3.85
I found 6.0 gto longtube headers cheap so those wont fit the 3gen even with tubular kmembers
1984HO
Mar 19, 2021 11:59 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
