Would this header fit?
Old Dec 27, 2010 | 03:11 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Im in the middle of dropping in a GM crate engine with vortec heads. Im not trying to put anything expensive on, but i do want to get rid of the rusted out stock headers the engine came with. These headers fit vortec heads which is what i need BUT im not sure if it will fit into my 91 camaro with out issues. What would you say to as fitment in the actual car? They look as if any other header for our cars but sonce ive never bought headers before i would know what to look for. All help is appreciated thanks. http://www.kmjent.com/cart/product.p...0164598&page=2
Old Dec 27, 2010 | 03:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Would this header fit?
Not even close.
Old Dec 27, 2010 | 03:52 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Seriously! why do you say that?
Old Dec 27, 2010 | 03:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They'd go right through the firewall.
Those are truck headers. Only thirdgen application-specific headers will fit.
Old Dec 27, 2010 | 04:03 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Will vortec headers called ENGINE HUGGERS work? There kind of like shortie headers. If you can help me heres the link to my engine https://www.thirdgen.org/forums/engi...ng-engine.html would you be able to identify if i have angle plug heads or stright plug heads? That will help a lot
Old Dec 27, 2010 | 04:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Again, only thirdgen application-specific headers will fit. You don't need "Vortec" headers, you need thirdgen headers.
Old Dec 27, 2010 | 07:45 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
So wait i thought i needed special headers to fit the vortec heads?? Something called D port headers
Old Dec 27, 2010 | 08:15 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
The heads being vortec doesnt affect which headers you need one bit. Just ignore the vortec-ness and buy headers for your year of car with the normal v8. They're the same.
D ports are something else entirely.
Old Dec 27, 2010 | 10:30 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
So i can buy ANY header that fits a 91 camaro? Also should i be concerned if they are angle plug or stright plug heads? Or do i just get any header thats fits a 1991 camaro?
Old Dec 27, 2010 | 10:40 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Like he has mentioned over again. Only third gen specific headers. There is no difference header wise with the two different plug types, just that angle plugs make it easier to change the spark plugs and straight plugs sometimes require shorter body plugs so the wire boot doesn't touch the header.
JUST BUY 82-92 CAMARO/FIREBIRD SHORT TUBE HEADERS.(preferably that come with a y-pipe)
Old Dec 27, 2010 | 11:16 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Thank you, thats what i needed to know
Old Dec 27, 2010 | 11:18 PM
Sparkytfl's Avatar
You just might need one of these http://www.summitracing.com/parts/TFS-90500/
Old Dec 27, 2010 | 11:28 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Great thanks, now to be 100% sure about the header issue i was thinking of, this header will work will my application correct? Not trying to push anyones buttons but i was considering these first until some smart head told me i need vortec headers which was getting me confused. http://www.addoway.com/viewad/8291-C...-Header-335914
Old Dec 28, 2010 | 12:07 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Those look like they'll fit.
Old Dec 28, 2010 | 12:15 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Sweet, thanks everyone for the help!
Old Dec 29, 2010 | 10:04 AM
torque_is_good's Avatar
I've seen on this forum and others inquiries about those Chinese headers like those. The price is so attractive and you can also find them on ebay. Please let us know what was involved to get them to fit/not leak and how a y pipe was fashioned to fit. It might make for a good sticky. me, I took the cowards way and bought Hedman.
Street Lethal
Apr 30, 2019 12:14 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
Wvcamaro
Sep 4, 2015 08:38 PM
LilHot
Aug 23, 2015 09:36 PM
theurge
Aug 21, 2015 12:46 PM
