Ebay longtubes
Old Jan 12, 2022 | 06:13 PM
  #501
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Ebay longtubes
I put them in from the bottom. They slipped right into place, just wouldn’t bolt down. Never trimmed the trans either.
I don’t know what the difference is and at this point I don’t care. I’m glad most people have an easier time. I’m just here mentioning what I went through. Mine are in and the car drives great with no noticeable collision damage. Overall I’m happy, I just had to put in a lot more work than I expected. I would still recommend anyone that wants longtubes to give these a shot.
Old Aug 8, 2022 | 05:37 AM
  #502
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Ebay longtubes
anyone ever get these and just though a 3" muffler at the end of the Y connection? would be a lot easier than running over the axle. my current setup is hedman longtubes into s-extensions, x-pipe and flowmaster 44's.
thinking of getting these and putting a round magnaflow muffler right on the end of the Y. would that work?
Old Aug 8, 2022 | 12:13 PM
  #503
RoadRace's Avatar
Car: 85 IROC
Engine: 5.7
Axle/Gears: 4.11 torsen, 4th gen rear
Re: Ebay longtubes
what I have noticed is the difference in the actual headers themselves. For example the set I got actually had the lower section of 2 tubes on the pass side mitre-cut and welded instead of just a nice bend. Another set I saw had incomplete or missing welds.
it’s possible these really cheap ones are rejects from production for another supplier being sold out the back door for really cheap.
just a theory….
​​​​​​….as far as fitting a single muffler before the axle? It would have to be a shorter muffler but it would probably work.
Old Jan 7, 2024 | 09:11 PM
  #504
sublimed's Avatar
Car: 92 T/A Vert
Engine: L98 350
Axle/Gears: 4.10 Posi
Re: Ebay longtubes
Dropped the passenger side in from the top. Motor was jacked up. Removed the factory AC box for the install. Have test fitted the full size box and it will work but will be close.
The driver side needed to come up from the bottom.
Need a little more clean up but it is all going back together.
The headers fit well for the price. Had many of the same issues such as the drivers side control arm mount. The y-pipe did not have the funky junction but it is still not the greatest. The y pipes cleared the trans crossmember but it is hanging even lower than if clearance notched.
The provided u bolts are garbage and had a hard time sealing the headers and y-pipe. Swapped them out for butt sleeve style clamps. I’m going to take it to the exhaust shop and have them weld up some junctions and get a little more clearance.
I did not use the provided bolts or gaskets.
Mr. Gasket 7401G : Exhaust Gaskets, Aluminum
Mr. Gasket Company Headlock Locking Header Bolts - 2230G
Accel 8199 plugs but really only needed the short plugs on two tubes.
I had a set of MSD header wires at the house. Will probably swap them out because they are long.
Old Jan 7, 2024 | 10:25 PM
  #505
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Re: Ebay longtubes
Sublimed are these the same ones OP got.
Old Jan 8, 2024 | 08:06 AM
  #506
sublimed's Avatar
Car: 92 T/A Vert
Engine: L98 350
Re: Ebay longtubes
Yes they are stainless ebay, obx, dna , speeddaddy, dynowong, alibaba, china, headers.
They are knocks offs of the stainless works headers that hawks sells. They were $250 shipped from seller tcbmotors on ebay.
Old May 14, 2024 | 02:23 PM
  #507
Rodgersje77's Avatar
Car: 1989 Chevrolet Camaro Iroc
Engine: LT1 350 Carbed
Re: Ebay longtubes
Can anyone still find these on ebay I cant find them anywhere?
Old May 14, 2024 | 02:32 PM
  #508
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ebay longtubes
Might be these
https://www.ebay.com/itm/35535439839...mis&media=COPY
Old May 14, 2024 | 02:49 PM
  #509
Re: Ebay longtubes
You are the man thank you
Old Aug 22, 2025 | 02:26 PM
  #510
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Ebay longtubes
"Quote:
Originally Posted by Meatman
So did you ever install ebay longtubes on your T56 car? Several guys have purchased them and set out with intent to install and never came thru with fitment results.
Cory"
Sorry for the late reply. I did have to ding a few spots for clearance but the fitment is great with the 1993 LT1
t56. Sadly I haven't finished my project but I think I have a couple of pic buried that I will try to dig up
I have advanced heart failure and it's hard to climb under the car.
Ground clearance is excellent.
Plenty of clearance from the DS header to the slave cylinder.
Tons of clearance to the steering shaft.
Zero issues with the PS header.
Vortec head spark plug clearance was good but I dimpled 1 tube to get a 1/4" clearance. If I bought a shorty plug it would have been fine.
Old Aug 22, 2025 | 03:24 PM
  #511
RamIt's Avatar
Car: 1984 z28
Re: Ebay longtubes
Here goes a link good today. Even at $250 it's a great deal. Modify the Y pipe or throw it in the trash.
https://www.ebay.com/itm/26643046077...Z4DPC3ZSZC0J9N
Eric-86sc
Jun 22, 2016 10:18 PM
BASSr
Feb 23, 2013 08:36 PM
gad
Apr 5, 2011 01:27 PM
alloy
Jan 14, 2003 03:46 PM
