Mid length header that comes straight back
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Off hand, can anyone think of a shorty or mid length header, in a 1 3/4" primary that on the left (driver) side sweeps back, rather than turns towards the oil pan?
Thirdgen shorty's cannot be used with dual exhaust for this very reason, they are made for a y-pipe.
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Mid length header that comes straight back
The only thing I could think of offhand is the ¾-length headers you can get for the old 70's G bodies (they work great on 67-72 trucks). Short of making your own, that's all I know in a mid-length. I'm not really sure if even those can be had with 1¾" primary, though.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Maybe even S10 v8 swap headers?
-- Joe
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Well not so much that they're designed to use a Y pipe as they're designed to cross over. There's not much room to run pipe inside the frame rails, so if you're going to run pipe straight back you may as well use long tubes... which are really mid-length.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
I've done true duals with headman shorties, with a moroso kick out pan, maybe killed flow but possible. You maybe able just to use a chop saw and straighten it, I also had my slps rebuilt to clear my k memeber. Not above customizing headers, I'm also running true duals with original routing for y pipe, took care of ground clearance issues.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Too bad the 2210s are soo low. The set I had was all smashed from ground contact. Fine for a track car, not so good for the back roads of New Hampshire...
-- Joe
Engine: TPI 305/ v6
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
His headers look nice, similar to SLP's. However, they are meant for a y-pipe, and are very expensive. Probably a good bargain for the Cali boys with their strict emissions standards.
I'm at the point where I'm considering just making a set using a summit kit. I have a tig..
-- Joe
-- Joe
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Dyno Don's headers are cheaper than ceramic coated Hooker 2055's...
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
$800 with y-pipe...
http://www.top-downsolutions.com/powertrain-performance
2055's ceramic coated are $700.
http://www.summitracing.com/parts/HOK-2055-1HKR/
(just saying)
I spoke with Don, and he isn't interested in making a set that sweeps back on the driver side for guys like me with 3" pipes that straddle the transmission. It would probably cost him more to make a special Jig for a potential of only a few sales, can't blame him.
Why the aftermarket doesn't make 1 3/4 headers for thirdgen is beyond me..
Ebay is filled with STAINLESS 1 5/8" shorty headers for $160 a set. If they made 'em in 1 3/4" they would sell boat loads.. A Summit weld up kit, with flanges for a 1 3/4" shorty header is around $160. Maybe I should start making these things. I do have a TIG.
-- Joe
(just saying)
-- Joe
mdtoren
Aug 16, 2015 05:45 PM
