Trying to make power through shorties?
Old Jul 11, 2013 | 04:47 PM
3rdgenlewis's Avatar
Car: 89' RS.
Engine: Carbureted 305.
Transmission: Built 700R4.
Axle/Gears: 4.56
Yes I did a search, no I didn't find what was I looking for.
Anyway..
I have a set of SBC Shorties from Jegs, I was thinking of installing those in place of the stock manifolds, using the stock Y pipe w/ a cat delete, back to a single in dual out borla muffler and tips out the back.
Is this a good setup for reasonable power? Is the stock Y pipe really choking the engine up that bad that it shouldn't be re-used?
Details: 305 with a 600 CFM on top.
Old Jul 11, 2013 | 06:06 PM
Z28/ZR1's Avatar
Re: Trying to make power through shorties?
Low to mid rpms shorties are good. The biggest choke point are on cars equipt with the single cat design, as both exhaust manifolds are forced into one cat.
Old Jul 11, 2013 | 08:02 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Cant use your stock Y. Stock y will work with stock manifolds and that is it. Every set of headers for these cars comes with a matching y that works with those headers. You need a y for those headers if you are going to run them.
Old Jul 11, 2013 | 08:11 PM
Car: 89' RS.
Axle/Gears: 4.56
Erm, don't see why. I threw SBC shorty headers on my 92' Silverado and they bolted onto the stock Y without a problem at all. The headers came with the car, that's why I even thought about using them haha.
Old Jul 11, 2013 | 08:19 PM
Chad85T/A's Avatar
Car: 85 T/A
This is not a silverado. Most of these guys know what they are talking about because of experience. You asked a question, it was answered and then you turned around and say " shorty headers worked with my silverado's factory Y pipe". Who gives a **** about your silverado? We are talking about third gens.
Old Jul 11, 2013 | 08:21 PM
Car: 89' RS.
Axle/Gears: 4.56
Calm down, jesus christ. It was a statement, because I was just surprised.. I figured everything was pretty generalized.
Old Jul 11, 2013 | 08:31 PM
Chad85T/A's Avatar
Car: 85 T/A
I would say trucks are definitely more generalized. From everything I've read on here and doing research I dnt believe there are any headers out there that will just bolt in place of your manifolds w/o any Y pipe modifications.
Old Jul 11, 2013 | 08:50 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Pipe is cheap, Put the headers on and build a set of true duals from there back. all you need is a set of glass packs and dump em by the rear wheels and put in a pair of low restriction cats if you need them.
Old Jul 11, 2013 | 09:05 PM
Car: 89' RS.
Axle/Gears: 4.56
That's what I'm thinking.. it's just getting under the damn thing. Lol.
jaridjohn
Jul 8, 2024 03:49 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
86White_T/A305
Aug 17, 2015 12:16 AM
novaderrik
Aug 10, 2015 12:44 PM
