Cat delete issue
Old Nov 9, 2019 | 02:25 PM
K7dan's Avatar
Cat delete issue
Decided to delete the cat today. I have a 91 with a 305 Tbi. I went to take off the cat because it’s clogged and I was just going to straight pipe it. ( I know the emissions law and everything) but still going to do it. Anyways I noticed there’s a small tube going into the cat as well coming from the header it looks like. What can I do with that tube? Would it effect anything if I block it off or just leave it open? Thanks! I’ll get some pics up in a bit.
Old Nov 9, 2019 | 03:26 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: Cat delete issue
It injects clean air into the exhaust. If you cap it off, or leave it open, it won't do anything bad.
Old Nov 10, 2019 | 05:31 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I usually have it welded into the exhaust. I Don't think plugging it would be good if your smog pump is pumping air through it.
Old Nov 11, 2019 | 01:01 PM
K7dan's Avatar
Sounds good thanks guys. I left it open for now until I removed the smog pump/ a.i.r. box components. Does anyone know what size the threads are on the holes on the headers? I want to plug them up.
Old Nov 11, 2019 | 04:08 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
I WANT to say that its 3/8" NPT. Hard to remember exactly since I did mine 12 years ago lol.
What I'd do is take it all off, then cut off one of the fittings and bring it up to the hardware store to match up to be sure. I just used brass plugs on mine and it worked fine.
Old Nov 11, 2019 | 04:48 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
1/2-20 in. inverted flare plug is the correct part for plugging the AIR threads in the manifold. Some people have used 1/4 NPT plugs and it worked since they are also 1/2-20 threads but on a tapered (pipe thread) body. But for the cost of the correct fittings I went ahead and spent the extra couple of dollars. Got mine at the local auto parts store (they had to order them in for the next day since they only had 3 on hand in store). I think they were a like $1.10 a piece.
Rock auto has them for $.65 but unless you are ordering something else, shipping might kill the deal.
https://www.rockauto.com/en/parts/ed...flare+plug,267
Old Nov 11, 2019 | 08:06 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
As stated by others, the fittings are NOT pipe thread. They are 1/2"-20 bolt thread. The tubes use flare fittings, but if you look in the holes, there is no flare to mate with the flare fittings, which is why I just used 1/2"-20 allen head bolts...
Old Nov 11, 2019 | 08:24 PM
T.L.'s Avatar
JBarr83
Jul 3, 2013 08:25 PM
FireBirdKnight
Mar 14, 2009 09:38 PM
Streetiron85
May 24, 2004 07:05 PM
Kleen RS
Mar 22, 2004 11:49 AM
IH8FORD
Aug 20, 2001 02:30 AM
