Exhaust Help
Old Apr 10, 2025 | 07:17 AM
pete2833's Avatar
Car: 1986 Camaro Iroc
Engine: 5.0 TPI
Exhaust Help
I am looking to replace the exhaust on my 1985 Iroc 5.0. I have the 4 bolt flange cat and intermediate pipe set up. Any systems for this type of set up or any intermediate pipes with the 4 bolt flange. I am having trouble finding a pipe or kit that will work.
Thx
Old Apr 10, 2025 | 09:16 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Exhaust Help
If you can't find one, could you chop the 4 bolt flange off your old exhaust, then chop and weld it to the front of your new "standard" aftermarket exhaust?
Old Apr 10, 2025 | 09:20 AM
pete2833's Avatar
Engine: 5.0 TPI
Re: Exhaust Help
That's what I was thinking of doing. The pipe after the flange is oval in shape buy eventually goes to 2.75". I would need to seem it at the point it goes back to round.
Old Apr 10, 2025 | 10:12 AM
Engine: LT1, L400
Re: Exhaust Help
Yep. Or if your aftermarket mid pipe is bigger (like 3"), you could cut the flange off that at the appropriate place, then slightly smash/ovalize it, then slip it over your 4 bolt flange cut off pipe and see where it matches the 4 bolt flange's pipe cross section and shape, cut and weld them together there.
Old Apr 10, 2025 | 10:13 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Exhaust Help
The cat back kits used to offer the 4-bolt flange option, but I haven't seen one in quite a while. I think the suggestion of using your old flange and a little bit of the existing pipe and adapting it to the new intermediate pipe is the best option.
Old Apr 10, 2025 | 10:41 AM
pete2833's Avatar
Engine: 5.0 TPI
Re: Exhaust Help
Thanks. May just use the current intermediate pipe for now. I had to cut it off at the muffler to get it off. So ordering these Tail Pipes
Amazon Amazon
Amazon Amazon
Then will get a muffler and a small piece for the inlet of the muffler to intermediate pipe.
Will be the cheapest option for now being that I am in the middle of restoring the car.
Any opinions on muffler ?
Was looking at the Dynomax Super Turbo
https://www.summitracing.com/parts/w...maro/year/1985
And the Magnaflow
https://www.summitracing.com/parts/m...maro/year/1985
Opinions ?
Old Apr 10, 2025 | 11:10 AM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: Exhaust Help
I have the Dynomax muffler (actually the entire exhaust system) no complaints. It has a nice sound IMO. Like the title says "turbo", the sound reminds me of the old generic "turbo" mufflers/dual exhaust that the local exhaust shop would put on before there was "name brand" besides Thrush Glass Packs from the 70s came on the scene.
Old Apr 10, 2025 | 11:35 AM
pete2833's Avatar
Engine: 5.0 TPI
Re: Exhaust Help
Thanks, The Dynomax is definitely less expensive !
Old Apr 10, 2025 | 01:25 PM
Car: '89 GTA
Engine: ZZ6TPI
Re: Exhaust Help
Muffler choice is personal preference and very subjective. Depends a lot on what you want. Dynomax is going to be closest to the original exhaust note, marginally louder. Magnaflow is louder than Dynomax, with a deeper tone. I had a Magnaflow on my car 20 years ago and liked it back then, but these days it would be louder than I would like. I guess I'm just getting old.
Mikey84z
Nov 20, 2015 01:37 PM
silverstang84
Dec 2, 2014 10:21 AM
bunnyfoofoo13
Apr 29, 2009 06:28 PM
87camaro kid
May 29, 2006 03:23 PM
no_car_yet
Aug 5, 2002 07:22 PM
