having touble removing smog junk
Old Mar 8, 2002 | 02:47 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I got the smog tubes of of the drivers side, and the front one loose on the passenger side. I cant seem to get the ones loose for #4,6, and 8 clyinder. Any tips would be appreciated.
I cant seem to see how the smog pump come off. I need help on this.
I know this is on the board, but when I put in smog pump in the search, it brougt up nothing.
thanks.
Old Mar 8, 2002 | 03:03 PM
TtopIroc's Avatar
have u tryed going under the car to get to them?
just an idea I have no clue
Old Mar 8, 2002 | 09:12 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
penetrating lube and let it sit then brake em loose. or try to get a cheater pipe on there
Old Mar 9, 2002 | 12:30 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Yes, penetrating lube, use it before you break one of the bolts like I did. PITA to get the rest of the bolt out.
Old Mar 9, 2002 | 10:29 AM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
as for the smog pump . take the 3 bolts out of the pulley . after the pulleys off you will see 2 torq bolts (t-45 i think)& a regular bolt & it should come out the bottom. any questions just e-mail me.
Old Mar 11, 2002 | 07:43 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I got the rest of the smog tubes off this week end. #8 was a bitch. I thought I had to remove the pulley from the smog pump, but was not sure.
Thanks.
Did anyone notice any difference with their car after removing the smog.
I am going to get rid of my duel cats, and replace them with pipes.
Hopefully I will be going to the hedman elite headers later on.
Old Mar 11, 2002 | 01:06 PM
no difference but looks cleaner
Old Mar 11, 2002 | 01:15 PM
speedfreaker's Avatar
i noticed a big diff taking all of my smog off expecally the pump and belt i also took the christmas tree looking tubes off my manifolds and pluged them with brass plugs
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jonesyfxr
Sep 26, 2015 02:08 AM
Amillionoh7
Sep 11, 2015 11:36 AM
