Looking for a set of heads
Old Nov 6, 2008 | 03:36 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
im looking for a set of heads that will fit on a 305tbi thats not to expensive thanks Jon
Old Nov 6, 2008 | 04:12 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
Re: Looking for a set of heads
you want used heads/new heads? What is too much? What are you looking to do with/to your car? Blind recommendations are everywhere, if you want good answers or possibly the best one, we might need a bit more info from you as far as your expectations. You've given a start by telling us its a 305 tbi, if you look in the tbi section of the forum there are a number of stickies, and individual posts on good heads depending on application.
Old Nov 6, 2008 | 08:14 PM
Car: 1991 Trans Am
Axle/Gears: Stock
im looking for used heads that are pretty good im willing to spend between 50-200 im not in desperite need for them i would like to get them to have because mine are getting worn out im just looking to get power out of my motor i got a comp cam coming and an edelbrock intake manifold coming.
I already have headers full exhaust chipped ud pulley set ram air intake off the tbi msd wires cap rotor and accel header plugs and more but i still want more out of it. btw thanks for telling me about the tbi section ill go look at the stuff on there.
Old Nov 6, 2008 | 11:01 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
got a set on a 305tpi engine..$75 you can have them
Old Nov 7, 2008 | 08:50 AM
Car: 1991 Trans Am
Axle/Gears: Stock
are they stock heads? and are they in decent shape anything wrong with them?
Old Nov 7, 2008 | 09:56 AM
tpi-hearse's Avatar
yes stock 081 heads still on motor car ran fine
Old Nov 7, 2008 | 10:51 AM
95talonawd's Avatar
Car: 2001 Camaro SS
Engine: LS6
Axle/Gears: 4.10
I have a set of corvette heads 10088113's
Old Nov 17, 2008 | 11:59 AM
rce2win's Avatar
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
I have a set of heads still bolted to the block out of my '88 IROC. $50 and they're yours. Shipping might be the only issue. I could send them via Greyhound Shipping...would save you some coin. 85,000 original miles on the motor and ran fine when i pulled it.
PM me and LMK if you're interested.
Old Nov 18, 2008 | 09:29 AM
mamjme's Avatar
Car: 1986 camaro
Engine: 406ci
Transmission: th400
Axle/Gears: 3.55
I have a set of REman. 305 high output heads off a TBI with 8,000 miles. Nothing wrong with them. I installed a 350 a year after installing these on my last motor. Hard set of heads to find. $75.00 plus shipping. In Maryland
I also have a set of reman from the machine shop. never used TBI heads from a 350 motor with big valves. This will also bolt right up to a 305. valves been cut , newseals, milled, presser checked. Big up grade and HP for your 305. $150.00 plus shipping
evilstuie
Feb 28, 2016 03:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
