Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
A-Pillar gauges
Old Mar 5, 2005 | 07:51 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
A-Pillar gauges
the only way that i've seen A-Pillar gauges put on is by screwing them on directly to the A-pillar cover. i've always wondered if it's possible to cut out part of the cover and insert the gauge pods from the inside of the cover instead of the outside. has anyone tried this? post pics.
Old Mar 6, 2005 | 04:34 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I believe the triple gauge pods from Autometer are a full A-pillar replacement piece, at least that's what I've heard.
As for cutting out the pillar and putting the pod in. That wouldn't work since the single and dual pods are made to fit around the OEM one. You would still have a bottleneck affect on each end. Only way would be to custom make the insert or just make the full a-pillar in one piece.
I would look into the triple A-pillars if I were you.
Old Mar 6, 2005 | 01:31 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
The Autometer 3-gauge A-pillars aren't a bolt-in replacement, it's just a cover like the rest. The difference is, it covers almost the entire plastic, so the seams aren't visible. I don't like the little mounting tabs they provide, so I put mine on the stock plastic with model cement, then sanded the edges a little to blend it in better. It came out looking pretty good.
I ended up taking it out of the car though....it was pushing on my dashpad and I didn't like that.
Old Mar 7, 2005 | 01:10 PM
eagle_eyes's Avatar
Engine: '93 LT1
i was thinking about that too, but it is plastic: cut, bend, melt...etc. and it might be possible IMO.
Old Mar 7, 2005 | 10:54 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
autometer makes replacement a-pillar moldings for t-tops as well as hardtops. they are an a-pillar pod that replaces the whole piece.
Old Mar 8, 2005 | 01:44 PM
TheGreatJ's Avatar
Nope. Read my previous post. I bought one thinking just that (since it is basically what their ad says, after all) but still had to do some minor fabbing to make it actually stay on the pillar. It doesn't just "bolt-in."
Old Mar 8, 2005 | 03:49 PM
Engine: 383 SBC
Good I wasn't the only one that thought that. I think it was the Sales people from Jegs or Summit that told me that to begin with when I was on backorder for a triple pod for 5 months.
Old Mar 9, 2005 | 09:48 AM
mw66nova's Avatar
Engine: 7.0L
p/n's for full pillar replacement pieces
hardtop:
2 guage: 12200
3 guage: 12201
t-top
2 guage: 12202
3 guage: 12203
Old Mar 9, 2005 | 02:02 PM
TheGreatJ's Avatar
12203 is NOT A FULL PILLAR REPLACEMENT. It's a full-length cover that mounts to the stock pillar plastic. It will not mount to the steel pillar directly, unless you fabricate brackets and drill holes for screws. All of them are that way (for the third time.) Buy one, wait 6 months for it to come off backorder, and see for yourself. I did.
Old Mar 9, 2005 | 03:00 PM
Engine: 383 SBC
You got lucky! They eventually just left me a message on my answering machine stating they removed me from the backorder list after how many months it was. That was really nice of them without any questions first.
Old Mar 11, 2005 | 09:41 AM
eagle_eyes's Avatar
Engine: '93 LT1
thank you for the replies, but has anyone ever tried my origional question??
Old Mar 11, 2005 | 11:49 AM
mw66nova's Avatar
Engine: 7.0L
i believe the answer to be:
NO. but you could be the first one to try it!
Old Mar 14, 2005 | 07:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Go for it; just get a scrap pillar from a junkyard car first. I guess you'd need one of those "plastic welders" (http://www.eastwoodcompany.com) , or maybe you could just join it together with a soldering iron. You'd have to be real careful to try and hide the seam, though.
I guess you could also wrap the pillar in black cloth, too- that would definately hide the seams, and it'd look great, too.
Old Mar 21, 2005 | 07:50 PM
Eastside_gizz's Avatar
Car: 92 firebird
Engine: 350 lt-1
Transmission: 700 r-4
Autometer
I have the autometer 2 gauge a pillar pod it has 4 push in christmastree's to hold it on mine have never came loose and if your pillars look good you dont even notice that they are over the other plastic looks nice. http://www.cardomain.com/memberpage/282340/3
Old Mar 26, 2005 | 01:30 AM
eagle_eyes's Avatar
Engine: '93 LT1
i'm going to try and do this...it's not that much about looks as it is about being different. it might take a while because i'm pretty busy, but i'll keep you updated on the progress when i start it
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
