Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Instrument swap
Old Jun 5, 2005 | 12:42 PM
john1221's Avatar
Car: 89 IROC Convertible
Instrument swap
Has anyone attempted putting a 90-92 camaro instrument panel in an 89 or older model? I like the look better but I understand its electronic speedo vs mechanical. I am getting the entire parts car so that would not be a problem.
Old Jun 8, 2005 | 11:04 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The entire cluster is a different shape, so unless you plan to do a lot of custom fabrication, you'll have to swap the entire dashboard.
The wiring harness is going to be different too, but my guess is that all of the wire colors should be the same, so it shouldn't be hard to figure out the wiring.
Old Jun 19, 2005 | 03:52 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I was doing some searched to locate info on how to wire my 91 cluster to work with my engine swap. I found a thread where some guys did take the newer cluster and put it into and 89 or older 3rd gen. Only problem is I can't find the thread(it's like 3 years old)
Anyway, I can't remember what the guys said about making them fit, but one guy had the wiring codes for both clusters so they could wire them and make them work. I e-mailed him and he sent it to me. I have the small piece of info if you like.
Old Jul 7, 2005 | 02:17 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
Could you send the info to me or post it, I am planning on doing an engine swap as well, and maybe a dash too. (I'm still in the reasearch phase).
Old Jul 7, 2005 | 10:11 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Here you go this should help
https://www.thirdgen.org/techbb2/sho...hreadid=186037
Old Jul 8, 2005 | 09:35 AM
vrtc350's Avatar
Car: 81 Corvette
Well I tried to post it up a couple of times but the file is still to big. If I shrink it anymore you won't be able to read it. I'll just e-mail it. I need to figure out a place to host it.
Old Jul 8, 2005 | 10:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
email me the file, and i'll post it up with my other wiring stuffs.
MrDude_1@excite.com
Old Jul 8, 2005 | 10:59 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i got your email, and its online here:
http://66.83.134.202/travis/91FbodyW...and%201991.htm
ALL 1991 Fbody wiring can be found in the PDF files in this directory:
http://66.83.134.202/travis/91FbodyWiring/
Old Jul 8, 2005 | 12:16 PM
vrtc350's Avatar
Car: 81 Corvette
Awesome, I may need some of those other diagrams. I'm getting ready to sort out all of the electrical stuff to get my engine swap finisthed.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
