Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
350 Engine Brace?
Old Jul 19, 2005 | 10:40 PM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
350 Engine Brace?
Using this part as i guide, I was hoping to fabricate an engine brace, but i wanted ideas from people on where on the motor and chasis it should be mounted?
Any thoughts?
EDIT: Or should solid engine mounts be my first defence again engine movement?
Old Jul 20, 2005 | 05:19 AM
ede's Avatar
ede
mine is bolted to the left head and then inner fender directly left of the location it's bolted to the head.
Old Jul 20, 2005 | 06:30 AM
Any chance of a pic mate? Keen to see where on the head you bolted it to.
Old Jul 20, 2005 | 06:40 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Wrong part.
Old Jul 20, 2005 | 08:03 PM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
I used a short piece of log chain that goes from the from to an empty bolt hole on the lower half of the motor. It is very concealed. It is very cheap to, maybe a dollar and an hour of work.
Old Jul 20, 2005 | 08:58 PM
To what part of the chasis?
Old Jul 21, 2005 | 12:00 AM
83 Crossfire TA's Avatar
My ’83 TA used to chronically destroy driver’s side mounts and I finally ran a length of chain from the driver’s side head to one of the K member blots (one of the ones that holds the triangular brace between the front of the k-member and the driver’s side frame rail)
Old Jul 21, 2005 | 12:02 AM
Thats all i needed to know. I've got the solid mounts on the way, but i might hold off on installing them and see if this chain method solves my problem first.
Jake_92RS
Jan 28, 2020 10:37 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
NBrehm
Aug 5, 2015 07:57 PM
