Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
finished home made subframe connector pics inside
Old Mar 13, 2006 | 11:30 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I am not a fabricator so dont look too close. post any questions or comments. whole setup cost me about $8
Attached Thumbnails finished home made subframe connector pics inside-driverfull.jpg
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
passenger side
Attached Thumbnails finished home made subframe connector pics inside-passfull.jpg
Old Mar 13, 2006 | 11:31 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
view of passenger side from front
Attached Thumbnails finished home made subframe connector pics inside-passattach.jpg
Old Mar 13, 2006 | 12:13 PM
BranZ's Avatar
Car: 1991 Z28
Engine: 5.7
Transmission: A4
That is a nice job. Do you have any pics where it mounts to the back of the car? BranZ
Old Mar 13, 2006 | 03:25 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Yes I do but it puts me over my pic limit i think. Maybe the mods will have mercy on me since these pics will actually be helpful so some folks on here.
Attached Thumbnails finished home made subframe connector pics inside-driverrear.jpg
Old Mar 13, 2006 | 04:35 PM
BranZ's Avatar
Car: 1991 Z28
Engine: 5.7
Transmission: A4
Beautiful work! What side tubing did you use for them? I need to tighten up my 91 Z28. Did you use a hydraulic bender for the bends. Please share, please share. BranZ
Old Mar 13, 2006 | 04:55 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
The main tubes down the sides is 1.5x.157" so it is pretty strong stuff. The tubes that tie into the front subframe are 1.5x.125". I used 1/8" (.125") plate in the back where the tubes tie into the control arm mounts and welded it as far around the perimeter as I could reach with the torch. I also used plates where the tubes meet the front subframe. Up front I welded the tube to the plate then I welded the perimeter of the plate to the car and I also drilled 4 holes in the plate and plug welded the plate to the frame as well. I wanted to spread the load where the tubes attached to the chassis which is why is used plates everywhere. As many will tell you welding the tubes to the body seam is a challenge wo get good penetration but not burn through the thin sheet metal. I eventually got it though. I used a cheapo bender of my Dad's. It is basically a 12 ton bottle jack in a frame with dies. I used a sawzall to make all of my cuts. I also used a grinder and a welder to complete the task.
They are really not as heavy weight wise as I thought they would be but they seem strong. I still have not taken the car off the jackstands yet because I am installing new carpet, but the doors already shut better which suprised me.
Bring on more opinions, I want to see what you guys think.
Old Mar 13, 2006 | 05:57 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
they look great and so do the welds, when you get her on the road let us know how it feels
Old Mar 13, 2006 | 06:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
torch? you mean a TIG torch, or a torch torch?
Old Mar 13, 2006 | 08:24 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
I was thinking the same thing.
they look good though. I like how the rear plates extend to include the bolts for the LCA's
Old Mar 13, 2006 | 08:34 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
For not being a fab guy, they look like they were made by a fab guy. It looks & sounds like you used the right material. Nice job.
Old Mar 13, 2006 | 08:48 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Thanks for the compliments guys. My seats should be done in about a week so. Then I can have the car on the road again barring any increased salt application here in northwest OH.
By torch guys I meant MIG welding torch. I used a Lincoln MIG welder.
THanks again for the compliments guys, keep them coming!
Old Mar 13, 2006 | 09:48 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
What model of Lincoln is it? The reason I am asking is beacuse I will be getting a welder soon and was thinking about the Mig-Pack 3200. Just wanted to hear some input.
Old Mar 13, 2006 | 11:29 PM
83 Crossfire TA's Avatar
besides the braces in the front they look almost identical to the GW ones... The only other difference that I see is that the back plate goes all the way to the pivot bolt where then GW ones don't.
Aren't there some that actually come with braces like that?
Old Mar 19, 2006 | 07:25 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
*LOL* I got some tubing at work, but it sure is thicker than .120, may be very very close to .20 or even .25 sure a bit heavy but hey it'll be stiff alright.
I love when people post pics of their homemade SFC's.
Good job !
Old Mar 21, 2006 | 02:53 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
want to make me a set?
Old Mar 21, 2006 | 04:08 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
can anyone else not see the pics. when i click to view i get a blank page. when i download them to my local machine i get "clear.jpg" tried IE and firefox. i realy want to see these as i am considering making a set for myself.
Old Mar 21, 2006 | 04:15 PM
JBert's Avatar
Car: Looking
I think this is one of the posts that the mods were talking about that would loose the attachments over the re-do.
Old Mar 21, 2006 | 06:41 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Hey- for some reason it wont let me view the pics..
Could you e-mail them to me with dimensions- im kinda wantin to make a set also.. Thanks!!
txmxrider_1569@hotmail.com
Old Mar 21, 2006 | 07:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
my hotchkiss SFC's went all the way back to the lca bole hole. I can't see the pics anymore, so i'm not sure if we're talking about the same thing though.
Old Mar 22, 2006 | 11:07 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
i could use pics to i am thinking make my own also
Old Mar 22, 2006 | 12:03 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Is that better guys!!!! For those asking for dimensions, sorry, i only have dimensions for the plates, i reverse engineered the tubes to fit the car so I dont really have any solid dimensions I can give out.
Old Mar 23, 2006 | 07:09 PM
Car: 88 IROC
... want to make me a set?
Old Mar 23, 2006 | 07:16 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
oohh- i see the pics-... I think im going to use 1/4 inch x 1 inch ID square tubing since we have a sh*tload layin in the welding shop at schooll he he he..
Also thinkin of makin a rear panhard bar out of the same square tubing- is this ok or do i have to use round tubing?
Old Mar 24, 2006 | 04:54 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I could be talked into making a set or two. I'll have to check material prices and get a quote around.
Old Mar 29, 2006 | 02:22 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
If your gonna make a couple sets, it would be nice if i could attain one. Very nice craftsmenship on those. They look as nice or nicer than some commercial branded ones.
Jeremys87
Jul 14, 2022 09:08 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
