Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom ram air
Old Dec 17, 2008 | 12:37 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Custom ram air
Ok, so I was doing some thinking, and I think I came up with a very unique idea for cold air on a camaro? Well you see... I plan to get the ss hood. So making that functional is a must. But also I was thinking about how you can run the piping from the foglights to get cold air. Now what I have thought of, that I don't think anyone else has done, was making it to where both of these areas supply cold air at the same time. For instance, have it to where when you close the hood, somehow, the foglight tubing, matches up with the ram air hood, and then goes straight into the TB. Which means twice as much air in. Being that I have the LT1, I thought this would be a neat idea, and a very beneficial one if done right... Keep in mind, this is still in thought.
Old Dec 17, 2008 | 12:46 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Re: Custom ram air
Hey man I dont know if you have looked into something like this for a ram air set up or not. But this may help you design your own custom job. check it out...
This is what it looks like installed on a car. They can be found here www.hawksthirdgenparts.com
Old Dec 17, 2008 | 02:25 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Re: Custom ram air
Yeah, I knew about those... but that, plus the ss hood ramair?
Old Dec 17, 2008 | 02:28 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Re: Custom ram air
That would be bad a** IMO. Just a thought I thinking building your own would be awesome too. Keep us posted I am really interested
-Darren
Old Dec 17, 2008 | 02:35 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Re: Custom ram air
Well if I'm not mistaken the Ram Air Firebirds and some of the SS Camaro's (4th gen) had a ram air box that matched up with the hood when shut. You could adapt somthing similar, with it hooking up to the TB in the conventional manner and the opening matching up to the hood. Then just pipe into the box from the front with your ram air from behind your fogs.
Just an idea
Max,
Old Dec 17, 2008 | 02:38 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Custom ram air
how do you get air to the radiator?
Old Dec 18, 2008 | 02:29 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Re: Custom ram air
myvmax1, that was pretty much the idea I came up with. Now comes the fun part? Getting it to work?
Old Dec 18, 2008 | 09:02 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Custom ram air
I plan to use the TPI air boxes to bring air in from the front then my daytona hood will work better to let hot air out the back. I plan to install my louvers on the hood flat (raised) and use the 1-2" piece in front of the louvers as my ram air.
Our Air Dams yo.
http://www.hawksthirdgenparts.com/ca...torairdam.aspx
You could easily route some dryer piping from the fogs to the tpi air boxes, up to a fitted air intake (as stated above) for use with the SS hood. Its not that hard, just needs to be done...some piping measuring and fitting. Good to go. Post up when done.
Old Dec 18, 2008 | 04:17 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Re: Custom ram air
Well here lies the prob... I have to finish building my LT1, and purchase an SS hood before any of this will take effect? Which sucks ****.
Old Dec 18, 2008 | 04:36 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Re: Custom ram air
Air coming in from hood and grill may be a bit of overkill. Engine can only use so much air.You also have to consider bad weather like rain. you want to make sure you have some type of baffle or a way to close off any way water might get in.Sun coast creations sells ram air hoods. Not sure if they have the SS style for 3rd gens or not(functional,that is)
Old Dec 18, 2008 | 10:24 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Re: Custom ram air
I will be making my ss hood functional. I did it with my aftermarket 4th gen hood. Im sure I can do it with the 3rd gen one as well
Old Dec 19, 2008 | 05:52 PM
Re: Custom ram air
check around. you can buy a ram air box that will fit. My buddy has one on his Formula
87iroctheo
Dec 4, 2016 11:47 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
bryan623
Aug 10, 2015 11:33 AM
