Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
NEED HELP WITH TOOL BOX PLZZ!!!
Old Mar 10, 2009 | 04:45 PM
Dwms23's Avatar
Car: 91 camaro z28
Engine: 350 borred out t a 383
im trying to put together a tool box with all the tools used on my 83 camaro cross fire inj. i just needa know socket sizes and wrench sizes and all that good stuff i could physically go out and do it but it would take way to much time plz help me with this
Old Mar 10, 2009 | 04:53 PM
Stephen's Avatar
Car: 87 GTA
Re: NEED HELP WITH TOOL BOX PLZZ!!!
For a 83....Buy all standard wrenches & sockets. Metric will only be "close" in some place & useless in most.
Old Mar 10, 2009 | 05:02 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Was it in 85 that they started using metric hardware? For some reason that number keeps coming to mind...
Old Mar 10, 2009 | 05:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
imperial on engine/tranny/rear end, metric on body etc.
That's on my '82, the '83 will be identical.
you will want an imperial and metric 3/8"drive socket set, and wrenches. for imperial and metric. extensions, swivels, etc etc. Get it all.
Old Mar 10, 2009 | 06:02 PM
Stephen's Avatar
Car: 87 GTA
My 87 is a total freak.....Just to pull the gauge cluster out, I needed 3 different sized metric sockets, 2 imperial sized and a screwdriver! And the metrics.....On one row of the "same" attaching bolts, they weren't even all the same size!
I think 87 & 88 (some) & by 89, all metric.
Old Mar 10, 2009 | 06:53 PM
Dwms23's Avatar
Car: 91 camaro z28
this helps a lil im lookin for actual sizes that you guys tend to use alot like for instance i use a 10mm socket alot on the car
Old Mar 10, 2009 | 07:34 PM
Stephen's Avatar
Car: 87 GTA
Buying a set of sockets, will be cheaper than buying the few (in that set) that you think you'll need.
Plus, if you only bought SOME, you'd get halfway though a project, only to discover you need ANOTHER size socket.
Old Mar 10, 2009 | 08:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yes, exactly.
I use 7, 10, 13, 15mm a lot. same with 1/2", 9/16" and 5/8". However halfway through, i'll need a torx T-15.... or a 7/16".. or a crescent wrench...
However, the above list is what I put in a duffle bag and bring to the junk yard... That and wire cutters and a hammer
Old Mar 11, 2009 | 01:46 PM
Dwms23's Avatar
Car: 91 camaro z28
sonix helped i have alot of tools and alot of extra tool boxes so i wanted to put a tool box together so i dont have to lug around my big tool box to my car everytime i can just take a small one you know what i mean
Old Mar 11, 2009 | 01:55 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Yeah my 88 is mostly metric, but I agree that buying a small tool kit would be great...
I got one for christmas, and it never leaves my backseat. When I go to use it I never end up telling myself "damn, I need more tools" its more like "damn it, should have brought the WD-40"
If I were good with fabrication, I would make some sort of utility box out of the locking space with the cardboard liner in the trunk...
Old Mar 11, 2009 | 06:31 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
some places have a "tune up kit" comes with roughly 10-15 standard sockets, 10-15 metric sockets, a spark plug socket, and a 3/8" drive ratchet all in a small package
Old Mar 12, 2009 | 10:21 AM
88camaroluvr's Avatar
Don't forget the trusty Gator Grip: http://www.sears.com/shc/s/p_10153_1...&keyword=gator
Just don't try and use it to torque a lot of things down.
Old Mar 12, 2009 | 03:51 PM
Brennan's Avatar
ive always wondered if they were any good
Old Mar 16, 2009 | 05:07 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Pick up a set of these, http://www.knipex.com/index.php?id=7...=86%2003%20300
I've got the medium sized one, it's the single most useful tool I own... the design lets you grab all sizes of nuts and bolts, like a crescent wrench, but unlike a crescent wrench you will never strip or round the head because of how it multiplies the force (full handle movement = about 1/2 inch of jaw movement, I've folded coins in quarter with mine), they're perfect for removal/install of same size nut/bolt combo if you don't have two wrenches the same size. Works great for removing stripped nuts and bolts or any time you don't feel like rummaging through the tool box for that one wrench that's at the bottom 'coz you never use it. The Gator Grip is almost useless in comparison... Get 'em from eBay, the set of three costs about the same as a single one from Snap-On.
Old Mar 16, 2009 | 05:20 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
+1 to these
pretty much anything knipex is gold. i have a set of side cutters I bought from matco (and paid waaaay too much) 5 years ago. I have cut probably about $40 bucks worth of pennies just to show off their capabilities and they still cut wire, zipties, and just about anything else with ease.
Old Mar 16, 2009 | 05:37 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
99.9% of the time when i work on older SBCs its 9/16 everything. I would make sure you have 9/16 sockets deep and shallow a 9/16 wrench for sure as well. Next ide have to say is a tie between 1/2 and 5/8 in and occationally 3/8 or 7/16. For the body and interior you run into alot of metric stuff so really ide recomend having a set of sockets standard from 3/8-3/4 and metric 10-19. I will say youll need a good ratchet with a few different size extentions and a flex head (also adapters if needed). I also like to have a breaker bar on hand. The star shaped tork bits are handy to have sometimes as well as allen wrenches. A few different screwdrivers especially a small flat bladed screwdriver to help with the electrical connectors. A magnetic pic up tool to help out with dropped bolts because they always fall into the most obnoxious places ever. Various types of pliers (needle nose, linemans channlelocks, and my favorite vice grips!). Penetrating oil will save you hours of misery on tough bolts i like to use PB blaster its the best stuff ive ever seen. I like to have a volt meter of some kind on hand. Also since i do alot of engin work the essential gasket sealers and thread sealers but i also toss in electrical tape zip ties ect. Maby toss in a chear repair manual like haynes or something and ide say your good for the basics.
Old Mar 18, 2009 | 12:23 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
deep 14mm is my best friend on any 80's-90's GM !
Besides they have been crossing metric and imperial since the 70's and it is really annoying.
Old Mar 18, 2009 | 09:33 AM
Sonix's Avatar
Car: 1982 Trans-Am
deep 14mm? I don't even own that I don't think - what on earth do you use it for??
Old Mar 18, 2009 | 11:21 AM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Pretty much all those old 9/16 that are out of shape or are a little stripped. Also 14mm is a common size for bracket studs and getting a deep one to get down the stud to the base. I just buy a couple cheap ones but I have like 3 craftsman now and I hammer them onto a stripped 9/16 and back them out (sometimes getting the bolt out of the socket is impossible so I take it back and get a free replacement).
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
92projectcamaro
Dec 8, 2015 12:25 AM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
