Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Is it ok to Cut out?
Old Jul 16, 2009 | 02:08 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Would it be ok to cut this out? X marks the spot and this would be on both sides of the car. Im thinking of doing something here. once im done with what i want to do i would support around my mod to get that a little stronger again. But just wondering if it would be ok. I dont want to car to fall apart LOL. thanks
Old Jul 16, 2009 | 09:08 AM
mroth2008's Avatar
Car: 2001 Mazada Protege es
Engine: 2.0L dohc
Transmission: G-15m-r
Axle/Gears: 4.10
Re: Is it ok to Cut out?
no thats part of your radiator and front clip brace
Old Jul 16, 2009 | 10:00 AM
zlathim's Avatar
That's the radiator support. If you cut it out, you will need to do some pretty serious fabrication to get proper structural integrituy back into the front of the car, not to mention securing the radiator.
It seems to me like it would be way more trouble than it would be worth, but you are rather vauge on what you plan to do. What are you trying to accomplish?
Old Jul 16, 2009 | 10:32 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I took some pictures of a little bit more detail. There is a radiator support already connected to the frame of the car. i would re-enforce that a little bit more. see pictures. that would take care of the radiator for sure. Now once im done doing my "secret mod" i would build around that. connect the body of the car back to the radiator support like it was before i cut it out. does this make a little bit more sense?
Attached Thumbnails Is it ok to Cut out?-img_0042.jpg   Is it ok to Cut out?-img_0043.jpg
Old Jul 16, 2009 | 10:39 AM
zlathim's Avatar
Yes it does. I guess it just depends on your fab skills and what tools and materials you have available. If you have the means to do it, then I say go for it. I want to see it when it is done. Don't worry, you can photoshop out the "secret mod"!
Old Jul 16, 2009 | 11:04 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I'm rookie when it comes to this fab stuff but if there is a will there is a way! Thanks zlathim!! I just needed to hear it from someone that it's ok to takle this. I do have a good welder, grinder. Pretty much all I really need. Don't worry you will be the first to see what the "secret" mod is. Let's just say that no one has done this at all but it has been thought of. Should have results this weekend
Old Jul 16, 2009 | 11:16 AM
zlathim's Avatar
Good luck, I can't wait to see the finished product!
Old Jul 16, 2009 | 11:44 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Thanks homie!!!
Old Jul 16, 2009 | 12:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Is it a dual snorkel intake with not one but TWO filters?
Old Jul 16, 2009 | 02:33 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Hahaha good guess but no lol your going to have to wait till I'm done. I will let you know when I'm done.
Old Jul 22, 2009 | 09:55 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
So you just wanted anyone at all at random on the internet to tell you it's okay to hack your car in that manner? And that was enough to make you feel good about doing it? Where do you plan to add additional bracing to make up for the loss of that structure? I'd suggest welding a brace that connects the top corner of the newly shortened radiator support to the frame rail near the steering gear. I'd suggest some decent sized angle iron.
Maybe you should post up your "secret mod" and get feedback on how well it would work before cutting up your car. It would suck to find out you overlooked something and hacked your car for nothing. If it hasn't been done yet (and just about everything has been done to these cars by now), maybe there's a reason it hasn't been done.
Old Jul 22, 2009 | 05:13 PM
Mathius's Avatar
I think it's an infinitely dumb idea, personally. Not only does that piece tie into your radiator support, it also ties in your inner fenders, which are tied into your strut towers, which supports your whole front suspension.
Not only that, but that whole frame helps support your headlight bar as well as your outer fenders.
But hey, go ahead and hack away. When you front wheels collapse, don't say you weren't warned. Hacking away at structural parts isn't something you just decide to do one day because you have some skills with a grinder and a welder.
Mathius
Old Jul 23, 2009 | 01:37 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Dont you think i spent time looking under my hood and thinking hard about it. I spent TO MUCH money on this car to mess it up now. Things are going really smooth right now. A lot better than i expected. I was able to get one side done. Look at the picture. Plus a nice strut tower brace should also help
Old Jul 24, 2009 | 06:31 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Are you notching it for a different headlight assembly? There's still some material there atleast. Can you fit what you're looking to do and box it in a little lower to reinforce it?
Old Jul 24, 2009 | 09:47 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Yes im putting in a different head light. The problem is the head light is pretty thick and it sits flush with the radiator support. there is not much i can do about that. but i can put some square tubing behind it. this of course would be hidden. but the support going from fender to to fender is just sheet metal folded into a square and its not really welded together just some tacks from factory.
Old Jul 30, 2009 | 11:26 AM
Mathius's Avatar
You didn't say anything about notching in your original post, you asked if it was ok to cut it out. Two WAY different things.
Mathius
Old Jul 31, 2009 | 09:27 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Mathius
Yeah i know. But like i said, things are go way better than i expected. So you think notching is a little safer idea?
Old Jul 31, 2009 | 08:32 PM
Steve86TA's Avatar
Car: To many to list
I think The question you first asked/showed and what you did were TOTALLY different..What you have now dosent look too bad. It looks like you still have alot of the integrity left in the rad support..still may need some sort of brace though..Good luck
Old Jul 31, 2009 | 08:54 PM
lv2bnmyz's Avatar
Car: 91 & 92 Z28 Vert
Engine: 91 305 92 383
Transmission: TCI Streetfighter 700r4
What headlight? I'm considering the same exploratory surgery.
Old Aug 1, 2009 | 01:03 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
The first picture i showed was worst case but after i got the head light where i wanted it, it didnt look that bad after all. I havent worked on it lately. i got one head light in and it looks real sweet. cant wait to show you guys.
Old Sep 1, 2009 | 12:44 AM
thecamarokidd's Avatar
Car: 1983 camaro z28,1970 gto
Engine: 355 sbc rollor motor
Axle/Gears: bull @#$% stock
i would love to know what your up to, cant wait to see
Old Sep 1, 2009 | 02:39 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I'd like to see also. I noticed a different than factory headlight in the first pic...is that what you're using? I'm guessing its something different than that..
Old Sep 1, 2009 | 03:53 PM
Orangepeeler's Avatar
There is a thread over in the appearance section. It looks incredible!! I think I would like to do this to my car.
Old Sep 1, 2009 | 04:47 PM
link please
Old Sep 1, 2009 | 05:23 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by thecamarokidd
link please
All you had to go to the user name of the one who started the thread, then look at Threads Started By......
2nd result gives....
https://www.thirdgen.org/forums/auto...onversion.html
Boy....That was HARD to find!
Old Sep 2, 2009 | 06:28 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
While I know how to do that, I'm sure there are people that have no idea that feature exists.
Old Sep 2, 2009 | 03:59 PM
. in case you haven't noticed im new to this site so im still learning how to use everything on here, your sarcasm was unnecessary
Old Sep 2, 2009 | 04:04 PM
Stephen's Avatar
Car: 87 GTA
Maybe so. I don't sugar coat things. Life is what it is. You may not like my attitide some times, but I certainly get my point across & am rarely misunderstood.
TGO forum basics are no different than all other Forums. Go to the member Profile & you can look through THEIR posts. Not even a whole website specific search. You can narrow things down to just one person on ANY forum site I've seen.
Old Sep 2, 2009 | 10:23 PM
well i dont know about you but this is my first fourm i dint find the need to be on a whole bunch of them i decided to come on here to learn more about iur cars and meet some good people. and imo there is no need to state your opinium in a rude manor, if some one ask for help you should do it in a respectful manor, im sure you would want the same if you asked for help and were un sure of something instead of someone basicly saying your an idiot its easy ect ect
Old Sep 2, 2009 | 10:29 PM
Stephen's Avatar
Car: 87 GTA
I wasn't rude. But tell you what....Next time I'll just go my way, let others help & offer no more help. That better?
Old Sep 2, 2009 | 10:38 PM
Boy....That was HARD to find! thats wasnt rude? all i asked for was the link, and you know what if your just going to be sarcastic about things then like you said let some one else help. i like this is how new members are treated who ask for help.
Old Sep 2, 2009 | 10:45 PM
Stephen's Avatar
Car: 87 GTA
Be grateful I even showed you, instead of telling you it existed.
It wasn't hard to find, which made your lack of looking obvious.
Like I've said before....People don't have to like my style of communication, but they can't deny that I get my point across.
Point is...You got the info you wanted. Let's stop littering this thread. If wanna bash me some more? Feel free to in PMs. People don't wanna read "junk" on Forums.
Old Sep 9, 2009 | 11:07 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Sarcasm...
Total lack of grammar & punctuation...
MERCY ME, I do love these urinating olympiads
Old Sep 10, 2009 | 01:44 AM
wow that's all i got to say
Old Sep 10, 2009 | 04:10 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
well this thread has been side tracked pretty bad, all over captain kidds butt hurt feelings. you have to take sarcasm from us with a grain of salt, otherwise shut up and leave. 6 post's complaining about it is just annoying and unproductive.
on that note,
Ramair21, get back to work, and finish your classified mod so we can see it already!
Old Sep 10, 2009 | 10:09 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
It's already finished lol. Check out the link above
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
