Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
lets see some pics of your custom mods and/or fabrication
Old Sep 10, 2013 | 08:59 PM
  #651
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Re: lets see some pics of your custom mods and/or fabrication
Originally Posted by KR81
It looks like the late 3rd gen bumper that retains the look of a trans am but has the opening for kitt's scanner lol. In any case your car looks awesome.
Thank you sir,
Def check out the build thread, tons of cool stuff.
But yeah I guess I could put one in it, just didn't want to get the KnightRyder look, too much, although all the kids in area already call it that...lol... but does look more aggressive IMO.
Old Sep 11, 2013 | 03:11 AM
  #652
KR81's Avatar
Originally Posted by BlackTopKing
Thank you sir,
I will check it out, you got a link? Over here, none of the kids know what Knightrider is, they just stop and stare when I drive past, with looks on their faces like wow, whats that thing lol. Older folks who remember knightrider yell it at me as I pass them.
Old Sep 11, 2013 | 09:49 PM
  #653
I'm pretty sure none of the kids ever watched the show they just know 80's TA = KnightRyder...lol...older crowd just think I'm nuts....but then again I think a chevelle on 28" is nuts....lol...so its all the same.
Just hard to try to change a TA to look completely different so a GM guy knows its different with out having it no longer look like a TA.
Old Sep 12, 2013 | 12:36 PM
  #654
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Anyone figure out how to make that shift light from the first page?
Old Oct 12, 2013 | 02:13 AM
  #655
85purpleZ28's Avatar
Car: 85 Camaro Z28
Engine: 355 TPI with F.A.S.T. Fuel system
Axle/Gears: 3:73
Picked this one on the way to the crusher last year. Plenty of parts made for it now. Lcarbs, adjustable LCA's, adjustable torque arm, sub-frame connectors, wonder Bar, heat extractor Hood, silver base with candy purple 95 Z28 disc brake rear. Dropped 2" Front 1.5" Rear on 20" rims. 2 12's in the storage in the trunk, components in the doors, amps in the side compartments. FAST kit 302000 wiring and ecm on tpi intake. Starting on the interior now.
Attached Thumbnails lets see some pics of your custom mods and/or fabrication-544957_326786827429122_1280904405_n.jpg   lets see some pics of your custom mods and/or fabrication-1146336_466646200109850_1599250267_o.jpg   lets see some pics of your custom mods and/or fabrication-397670_359074614200343_1842320655_n.jpg
Old Oct 12, 2013 | 02:20 AM
  #656
Car: 85 Camaro Z28
Axle/Gears: 3:73
Not sure why the phone made the powder coat look blue, it's actually candy purple.
Attached Thumbnails lets see some pics of your custom mods and/or fabrication-phone-151.jpg   lets see some pics of your custom mods and/or fabrication-phone-1296.jpg   lets see some pics of your custom mods and/or fabrication-phone-1191.jpg
Old Oct 12, 2013 | 02:44 AM
  #657
Primetime91's Avatar
Car: '88 Camaro (Gone...)
I don't want to be "that guy", but the welds on those LCAs look kind of sketchy to me. Just trying to help, be safe man.
Old Oct 12, 2013 | 09:59 AM
  #658
Car: 85 Camaro Z28
Axle/Gears: 3:73
There's two layers welded on each weld,but I have messed up things before lol. They have been doing good for a few months now though. However our insight did make me put it on the lift and check it, no cracks anywhere but I will keep an eye on it. Thanks.
Old Oct 13, 2013 | 08:09 AM
  #659
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
the welds look very cold from the pic. one lca has a jam nut for the rod end and the other does not. did you use tube inserts in the end of the pipe, or did you just tap threads into the tubing? also, what size threads are on the rod ends?
Old Oct 13, 2013 | 10:48 AM
  #660
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Just completed my composite headlight buckets as i will be using HID when i finish my restoration
lets see some pics of your custom mods and/or fabrication-headlight-conversion-3.jpg
lets see some pics of your custom mods and/or fabrication-headlight-conversion.jpg
lets see some pics of your custom mods and/or fabrication-headlight-conversion-2.jpg
Old Oct 13, 2013 | 10:59 AM
  #661
mjdavis68's Avatar
Originally Posted by Jk_Under
How did you do that shift light??? can you make a thread to explain a bit?
Nice Sir!, very nice
Old Oct 13, 2013 | 11:21 AM
  #662
WolfmanTA's Avatar
Car: 1986 Trans Am
Engine: LB9 TPI V8
Transmission: automatic
Here are some pic's of my Trans Am original Fog lights I rebuilt. Was cheap and easy way but looks 100% better. Wanted to keep the original shape. Sweet...
Old Oct 13, 2013 | 11:57 AM
  #663
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
That hood looks very nice with the "heat extractor" setup. Was that a kit installed in to the OE hood or a custom fabricated project?
Old Oct 13, 2013 | 04:36 PM
  #664
Car: 85 Camaro Z28
Axle/Gears: 3:73
They are 3/4" rod ends, and those were only in there for powder coating.
Just tossed the cracked plastic fins, flipped the hood over and cut out between the support underneath, then just cut the metal fins, welded them in place and ground the welds down smooth.
Old Nov 9, 2013 | 12:12 PM
  #665
cz28coptzer327's Avatar
Car: 84 camaro Z28
Transmission: borg warner T5
i dont know how it would look if you buy a camaro one because of the taillights wrapping around to the sides on a camaro.. and a firebirds dont..
Old Nov 9, 2013 | 03:13 PM
  #666
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Originally Posted by WolfmanTA
those look pretty much like the autozone/advance 20 dollar cheapies you can get, are those really the original for T/As?
Old Nov 9, 2013 | 03:26 PM
  #667
kmcn47's Avatar
Transmission: 5spd
so everyone will stop asking
buy one of these
https://www.sparkfun.com/categories/22
program it to flash at set rpms and handle the display of the numbers
have a switch or a sender at each gear position so that it will work properly
use the tach for the rpm signal
the installation should be the easiest part, remove cigarette lighter and its socket. install your new franken shift light that you made yourself
here is a link to the creators thread showcasing it, if you dont know how to do it then
ACCEPT THAT YOU WONT GET ONE, as far as i know he doesnt sell them and i really doubt any of you are about to go make yourselves one, so STOP ASKING ABOUT IT.
.......... also use the ****ing search function
Old Nov 9, 2013 | 09:37 PM
  #668
cagedruss's Avatar
Car: 84 Camaro Z28
Engine: 5.3
Transmission: Tremic 6 Speed
Axle/Gears: 3:43 posi
I needed to make a lower profile hood scoop for my Chump Camaro. I had some .040" Aluminum so I made a 3 piece simple low pro Z style hood.
Here it is painted and at the track.
Old Nov 9, 2013 | 09:47 PM
  #669
cagedruss's Avatar
Car: 84 Camaro Z28
Engine: 5.3
I replaced all the burnt tail light lenses from the Shop fire last year with some more Aluminum. I used 2 LEDs from Amazon for the Stop/tail lights. Didn't want to waste another set of Tail lights or pay the money for them also. The LEDs worked great at night 2 weeks ago, very bright and easy to wire up.
I did paint the center section before the race weekend.
Also did the aero strips across the roof and back window. Its just for looks plus they were fun to fab up.
Old Nov 10, 2013 | 09:34 AM
  #670
KBD85's Avatar
Car: 1985 trans am
Well, i may have my project in the wrong thread, I have this in the body section. but if you want to check out the whole build front start to finnish its under "FRONT BUMPER FIREMARO GRAFTING" here are a few shots of the project not quite finnished, but you can see what ive done.
Attached Thumbnails lets see some pics of your custom mods and/or fabrication-009-view.jpg   lets see some pics of your custom mods and/or fabrication-510.jpg   lets see some pics of your custom mods and/or fabrication-img_20131109_154004_242.jpg
Old Nov 10, 2013 | 04:17 PM
  #671
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I don't know what to think yet, post progress pictures as you go and how you did it if you don't mind.
Old Nov 10, 2013 | 04:43 PM
  #672
This is cool and I like the aero strips, very cool look
Old Nov 10, 2013 | 04:45 PM
  #673
Pretty cool.
Got pic with the primer bumper back on car?
Or a full shot? Is it as high as a TA bumper?
Old Nov 10, 2013 | 05:04 PM
  #674
KBD85's Avatar
Car: 1985 trans am
Yeah under the "body" section I have alot of pics. Not in primer yet tho. Just sprayed it last night. I hope to have paint on it next week.
Old Nov 10, 2013 | 09:35 PM
  #675
kmcn47's Avatar
Transmission: 5spd
you've made me wonder if i should remove the license plate box in my front bumper. and then make a custom grille..........hmmmm thank you? i think, looks good by the way, got a link to your thread?
Old Nov 10, 2013 | 10:52 PM
  #676
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
FWIW, you can grab the url from the thread and post it directly.
https://www.thirdgen.org/forums/body...-grafting.html
You can even grab the url of a specific post as well. example:
https://www.thirdgen.org/forums/post...57-post10.html
Old Nov 11, 2013 | 07:38 AM
  #677
KBD85's Avatar
Car: 1985 trans am
Thanks!!!!!!! im still trying to figure this computer stuff out. thanks for posting the link here!
Old Nov 11, 2013 | 01:53 PM
  #678
Scorpner's Avatar
Engine: V6, V8
You're welcome!
Old Nov 24, 2013 | 08:39 PM
  #679
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I've been tinkering with my project car that will ultimately be a 77 T/A:
In particular, the suspension that I came up with. I'm really liking the 4 corner air bags:
All that got me thinking about the Camaro, so I've just recently got to work on that too. First I made a strut mount that ended up enabling the front tires to droop an additional 3.5":
Surprised it only raised up the bottomed out height up about 1.5", comparing stock vs. modified:
It looks pretty wacky all drooped out, but I'm thinking traction will not be a problem:
File Type: jpg
Old Nov 24, 2013 | 08:40 PM
  #680
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I then went and swapped in some air bags, borrowed from the t/a project of course. I'm working on correcting some geometry issues as well by moving the control arm mount, and will be flipping the tie rod ends to the top side of the knuckles:
Somewhere in between all that, I drove the Camaro and ride quality feels unchanged by the air bags.
Old Dec 25, 2013 | 11:29 PM
  #681
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Originally Posted by wgpengineering
i noticed you and a couple other people are boosted and not running intercoolers...how much boost are you running?
I am running meth injection, but probably don't need it at 10 psi.
Old Dec 26, 2013 | 06:45 AM
  #682
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I've done a lot of mods to mine over the years, heres one of the last ones. A Cheetah Turbo action reverse pattern shifter.
I had to make a base plate to fix it to. I have the transbrake connected, but have a extra lock switch fitted behind the trunk switch to activate it. This also serves as the switch to operate the back up lights.
I like the way it looks, 80s shifter in an 80s car
Attached Thumbnails lets see some pics of your custom mods and/or fabrication-12-12-2013-080
Old Dec 26, 2013 | 11:12 AM
  #683
Pocket's Avatar
Car: 91 Trans Am
Just throwing it out there, but that strut mount isnt safe for use outside rolling around the shop. The strut does not extend/compress in a strait line, so a bearing of some sort is required
Old Dec 26, 2013 | 11:25 AM
  #684
DIGGLER's Avatar
x2. need to be careful doing stuff like this, as what seems to be harmless can turn out to be fatal.
Old Dec 26, 2013 | 04:56 PM
  #685
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I was looking at the strut movement with that plate the other day. The stock mount doesn't seem to have any give in it either. There is a ball bearing there, but that only lets the shaft of the strut not have to spin when steering. I noticed the strut moves quite a bit because of steering, but again I see no allowance for this in the factory mount either. Seems like even the factory mount should have a spherical bearing.
I've also since then got a 10 degree reamer and flipped the tie rod ends. That worked out very well, and there is zero bump steer.
Old Jan 17, 2014 | 11:10 PM
  #686
maule6's Avatar
Car: 92 RS Camaro T-Top
Engine: 305 V8
Transmission: 5 speed manual
Axle/Gears: stock
Just a couple pick of recent things I did
https://www.thirdgen.org/forums/inte...or-panels.html
https://www.thirdgen.org/forums/inte...ry-emblem.html
Attached Thumbnails lets see some pics of your custom mods and/or fabrication-2534_10200694820927771_1882046199_n-1-.jpg   lets see some pics of your custom mods and/or fabrication-1558438_10200710076789158_2042508909_n-1-.jpg
Old Jan 18, 2014 | 02:10 PM
  #687
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I seen a few dash mods on this thread so I'll just add my mod...
Old Jan 18, 2014 | 08:36 PM
  #688
maule6's Avatar
Engine: 305 V8
Axle/Gears: stock
How did you get that done? I've been needing to get some plastic done but not sure about seeing any "seems" in the plastic.
Old Jan 19, 2014 | 08:12 PM
  #689
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I'd like to know too. Turned out awesome! Cool, subtle mod if you've removed your heat/AC.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
87iroctheo
Dec 4, 2016 11:47 AM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
