Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
3rd to 4th gen rear end swap
Old Nov 11, 2009 | 10:55 PM
chrispy383's Avatar
Car: 92 rs 25th ann.
Engine: 383
Axle/Gears: 342
Will a 4th gen rear end ***. bolt into a 3rd gen shell?
Old Nov 11, 2009 | 11:19 PM
Stephen's Avatar
Car: 87 GTA
Re: 3rd to 4th gen rear end swap
The answer exists MANY MANY MANY times over, including all the details.
Old Nov 11, 2009 | 11:21 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Yes it will
Old Nov 11, 2009 | 11:31 PM
chrispy383's Avatar
Engine: 383
Axle/Gears: 342
thanks any extra bs I should know?
Old Nov 11, 2009 | 11:34 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
your welcome thats what i am gonna do too just need to replace the rotors and the pads from the rear end i bought
Old Nov 11, 2009 | 11:39 PM
Stephen's Avatar
Car: 87 GTA
Yes.... SEARCH!
The bolt in is easy part. The rest is explained by SEARCHING FOR THE THREADS THAT HAVE ALREADY COVERED THIS!!!!!!!!!!!
Sorry (OK, not really) but I am tired of reading the same crap over & over & over, because of people's inability to use the search feature that TGO already provides!
Old Nov 11, 2009 | 11:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Considering there's at least 10 years worth of archival material on TGO, just about anything that could be asked about third gens has been asked. Every now and then, something new does come up.
If you do ask the wrong questions, you will be corrected or steered in the right direction. Many people have far fetched ideas about something but have no idea exactly how difficult it would be to do.
A fourth gen diff swap is easy however it's not much stronger than what you already have. It'll have better brakes and has 28 spline axles compared to your 26 spline ones but you can easily upgrade your diff to be just as good as a fourth gens and not have to worry about the slightly wider width. Both diffs are equally weak with the tiny 7.5/7.625 ring and pinion.
Old Nov 11, 2009 | 11:53 PM
chrispy383's Avatar
Engine: 383
Axle/Gears: 342
SORRY!!!!!
Old Nov 12, 2009 | 01:12 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Originally Posted by Stephen
Yes.... SEARCH!
If you actually got an answer from doing a search instead of just being told to use the search feature in your search results, it would be a lot easier to use.
https://www.thirdgen.org/forums/body...tyres-3rd.html
https://www.thirdgen.org/forums/tran...s-am-rear.html
https://www.thirdgen.org/forums/engi...-gen-swap.html
https://www.thirdgen.org/forums/elec...lumn-swap.html
https://www.thirdgen.org/forums/tran...-gen-rear.html
https://www.thirdgen.org/forums/afte...2364-rims.html
https://www.thirdgen.org/forums/tran...tire-size.html
https://www.thirdgen.org/forums/memb...p-me-rims.html
https://www.thirdgen.org/forums/susp...044-tires.html
https://www.thirdgen.org/forums/tran...-rear-3rd.html
https://www.thirdgen.org/forums/susp...en-wheels.html
https://www.thirdgen.org/forums/whee...heels-fit.html
https://www.thirdgen.org/forums/whee...iroc-88-a.html
https://www.thirdgen.org/forums/whee...will-90-a.html
https://www.thirdgen.org/forums/inte...gen-seats.html
https://www.thirdgen.org/forums/brak...-rear-end.html
https://www.thirdgen.org/forums/tran...rear-into.html
https://www.thirdgen.org/forums/tech...t-4th-gen.html
Old Nov 12, 2009 | 01:18 AM
Stephen's Avatar
Car: 87 GTA
Learn to use the search feature correctly & learn how to refine your searches, not just typing in the first thing that comes to mind & giving up & it works wonders.
Should we hold a class?
#1, if those were your results, I see lots of things that wouldn't show up in a GOOD search.
#2, I see treads that (most likely, I'm not gonna read them because I already know whats needed & don't care to relearn) contain the answers.
#3, I do believe there is a sticky that covers it!
Old Nov 12, 2009 | 01:58 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
If your car originally had a 5.0 H.O with a T5, wouldn't it have originally had 3.73's and posi? I don't know why you would want to give that up...
But you apparently have 3.42's? Did your car originally have an auto? Or is everything I'm talking about only relevant to earlier years?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
