Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Im going to fabricate Rear lower control arms from scratch
Old Jun 27, 2010 | 11:54 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Monday im going to pick up some tubing to fabricate some rear tube control arms. 5 dollars for 2inch I.D.tubing, 26 dollars for bushings. ill update tomorrow
Old Jun 28, 2010 | 06:50 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Im going to fabricate Rear lower control arms from scratch
2" I.D.?? Whats the wall thickness? And what are you using for bushings/bushing housings? I hope youre at least upgrading to poly or sperhical bushings in the process? Are you TIG welding them or MIG?
Post pics when you get started for sure.
J.
Old Jun 28, 2010 | 07:32 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
LOL I was dreaming this up yesterday. My I idea is to use some 2" o.d. x 1 3/4 i.d square tubing and machine some ends with a bit more meat on the o.d to get welded on. The shop I work at does stick and mig so I should be covered on that end. The only reason I thought of it was I saw some tubing in the scrap bin and it looks like it will work, so I figured why not, I've already replicated a maf housing out of 4" sch 40 pipe and some angle iron.
Old Jun 28, 2010 | 07:45 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I was thinking the same originally and then I found these:
http://cgi.ebay.com/ebaymotors/82-02...item1c130712b7
I'm not gonna mess with it; I'm just gonna get those.
Old Jun 28, 2010 | 11:57 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
We had one member make a set of offset ones with square tubing for his large tire/wheel upgrade recently. Might get some ideas from his build.
Here's the link to his post. https://www.thirdgen.org/forums/fabr...et-street.html
Old Jun 28, 2010 | 11:22 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Those were actually a set of Lakewood LCA's that he modified, but same difference right?
If I ever made my own, they're gonna be out of billet aluminum & offset of course. Benefits of access to a machine shop
Old Jul 2, 2010 | 06:44 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
.240 wall? Little overkill
-- Joe
Old Jul 2, 2010 | 05:40 PM
Car: 1989 IROC-Z
.125, theres 2 walls
Old Jul 2, 2010 | 07:15 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ahh yes.. duh.
-- Joe
Old Jul 3, 2010 | 08:47 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Way big overkill!!! I used 1.250" moly with .090 wall and poly bushed moly ends with 3/4" threads and a 5/8" center hole.... No reason to put all that extra dead weight hangin' down there!!!
My car isn't even close to done, but a buddy volunteered to test the bars in his mid 11 '83 Camaro, they work great!!!
Old Aug 10, 2010 | 12:16 AM
Car: 1989 IROC-Z
Wait, how are you guys coming up with a .240 wall?? Am I missing something?
Old Aug 10, 2010 | 12:35 AM
I plan on constructing these trailer arms, as soon as i sell my vw engine i rebuilt for profit. I gotta a speeding ticket to take care, of. The dimensions are different now, im planning on tig welding them for sure, i just ran out of argon today, and picked up some lanthanum 2% electrodes also, so just as soon as i get the vw engine sold. I gotta say German engineering is another world
Attached Thumbnails Im going to fabricate Rear lower control arms from scratch-mms_resized_pix.jpeg   Im going to fabricate Rear lower control arms from scratch-engine.jpg   Im going to fabricate Rear lower control arms from scratch-hitlerbeetle.jpg
Old Aug 10, 2010 | 07:54 AM
Car: 1989 IROC-Z
I wonder if it would be worth it to make a 1 piece "I" beam type from 387 or 316/304 stainless. Think they might twist?
Old Aug 10, 2010 | 08:04 AM
Car: 1989 IROC-Z
I apologize, I'm thread jacking here, I'll search it. I just think its a waste to start a new thread instead of adding new ideas to an exhisting thread and give more information in one place rather than look all over the forum for bits of information. I'm sorry!!
Old Aug 10, 2010 | 10:19 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
I suppose you could, but why??? I beam structure would be more subject to twist then round tube moly, and much more difficult to machine for bushings, mounting hardware, etc.... If not moly, a size larger with a bit more wall thickness in DOM would do fine.
Old Aug 10, 2010 | 10:56 PM
Not to mention that stainless will fatigue over time, and is $$$
Sure is pretty though
Old Aug 11, 2010 | 09:22 AM
Car: 1989 IROC-Z
Lol I was bored, just throwing ideas out there. Imagine two 3/4" (maybe bigger) round bars, or similar square tubing, ran side by side with the ends welded on. That would twist too but, they would look really cool! Just trying to think outside the box (square tubing).
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
