Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
reverse hood opening?
Old Feb 9, 2011 | 02:57 PM
boby47's Avatar
Car: 84 Z-28, original owner
Engine: 305HO,+.030, mild cam
Transmission: TH700R4
Axle/Gears: 3.08, highway gearing, posi
84 z-28. I always liked the reverse opening hood on the mid 60's Vettes - a few quick measurings on 84 z-28 looks like I could put the Camaro factory hood hinges assembly on "backwards", that is, put the left side hinge on right front and right side hinge on the left front, in the fender lip like factory did it - drill and reenforce nut cups in the hood sides to attach the hinges , reloc the lift struts, bumperpads, etc. Put hood pins on the cowlside rear corners for hold downs.. could always try it with a fiberglas hood to have less weight to manage. anybody tried it? or have a better idea and experience??? thx
Old Feb 9, 2011 | 03:11 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: reverse hood opening?
Old Feb 9, 2011 | 05:20 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
my dads lesabre had reverse hood opening. the front lifted up before opening away from the windsheild. i would think the hinges from one of those old buicks/olds would be a better choice.
Old Feb 9, 2011 | 05:32 PM
Stephen's Avatar
Car: 87 GTA
Several 3rd gens already done that way & threads with pics on how it was done.
Old Feb 9, 2011 | 05:34 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
That's exactly what I used on mine. The width is the same between the buicks and f-bodys. Here's the link to my thread showing how I did it:
https://www.thirdgen.org/forums/fabr...erse-hood.html
Old Feb 9, 2011 | 05:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
https://www.thirdgen.org/forums/body...erse-hood.html
https://www.thirdgen.org/forums/body...tilt-hood.html
Old Feb 14, 2011 | 07:54 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
to me i like the idea of a reverse opening hood but the lesabre hinges just look tacky in my opinion
Old Feb 14, 2011 | 08:59 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
There is a buick in a upull it near me with one of those buicks with the reverse opening hoods along with the hinges. I know some people have found issues with the hood hitting the bumper when it is in the up position.
Old Feb 15, 2011 | 10:05 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Yeah, I ran into the same problem. I had to rework the stops on the hinges to eliminate that problem. I also had to remove the safety catch, or secondary latch, on the hood. Otherwise it poked into the front bumper where the front license plate mount.
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
