Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
hard top conversion to t top??
Old Jul 15, 2012 | 09:28 PM
Blue1990camaro's Avatar
ok i hav an 87 sport coupe im cloning to mimic a 85-90 RS, i hate hard tops, my iroc is t tops and i so wish my sport coupe was too, i dont wana sell it and buy a t top one..
soo is there a way i can make mine t top? the right way not hacked up?
Old Jul 16, 2012 | 11:47 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Re: hard top conversion to t top??
https://www.thirdgen.org/forums/body/648870-t-tops.html
Yes you can make yours a T-top car.The right way not hacked up? I think that would depend on your definition. You should call around to local fabrication shops and see what they think, unless your planning on trying yourself.
But remember, anything is possible if you can afford to pay for it
Old Jul 17, 2012 | 02:11 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Yeah but aftermarket t-tops never work like originals & they leak. I've seen it happen. It's gonna be pricey.
Old Jul 26, 2012 | 02:06 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
One more thread on a very good way to do it is here:
https://www.thirdgen.org/forums/body...-top-roof.html
He has some good pictures and explains real well exactly what he did and why.
Most commenting said this seemed the best way to do this.
Old Jul 26, 2012 | 02:37 PM
Car: White 84 z28
Engine: Chevy 350
T tops are cool, no doubt. They are also unique. But if it was me, i'd consider lopping off the whole roof for a convertable. Or big sunroof (because its simple).
But thats just me
Old Jul 26, 2012 | 05:19 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
The frame on a car with t-tops is reinforced from the factory. Cutting the roof of a hard top, you'll lose rigidity and could bend the frame. Be carefull.
Old Jul 26, 2012 | 05:28 PM
91phoenix's Avatar
I am not sure that is correct. The verts have a little extra reinforcements. But there seems to be no difference between hard top and T Top for the frames as they both take the same subframe connectors etc.
People have twisting problems with both.
Old Jul 26, 2012 | 08:27 PM
acechase99's Avatar
t-tops are not more reinforced from factory but you deffently need to weld in reinforcmentor find a way to keep it streight after cutting the roof .
seen ppl try to make targa tops from a t-top, good idea but only seen it successful a few times.
best way in my opinion is to cut the roof of of one and put it on urs so in the end it would be a lot cheaper because of already buying another car
best way buy a t-top f bodie that is striped for a few 100 bucks and swap your stuff over
Old Jul 27, 2012 | 02:06 AM
Car: White 84 z28
Engine: Chevy 350
I agree with that, would be way easier that way. But I bet you wouldnt need donor car. You could talk a salvage yard into letting cut it off like youd take any other parts im sure.
Still wouldnt be a small project by any means though. Youd have to cut each section from each roof at the exact same length.
Old Jul 30, 2012 | 02:45 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
if u got fios or direct tv, do a search for west coast customs episode, the did a red camaro for rascal flatts, hard top to t-top... one of the most compicated builds i ever seen! u gotta have good knowledge of cutting, welding, measurements , etc.... good luck
http://www.westcoastcustoms.com/pod-...flatts-camaro/
Old Aug 28, 2012 | 05:22 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
How bout a t-top to hard top???? Anyone ever tried??? Sorry for the hijack.
Old Nov 24, 2012 | 01:33 AM
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
I would trade for one straight up with someone that wants a hardtop instead. Do it to one that is in the same relative condition as yours for a easy and fair trade. No expensive headaches either.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Out-Cast
Sep 3, 2015 09:05 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
