Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Distributor Bolt Tool
Old Aug 13, 2012 | 12:32 AM
Unleashed Jimmy's Avatar
Car: 82 Converted IROC
Engine: 350ci TPI
Axle/Gears: 3.23 10-Bolt
After spending an hour trying to loosen the bolt for my distributor, it came to me. I need a tool!!! I had an extra wrench, an extra extension and a welder. This thing made the job really easy. Enjoy.
Old Aug 13, 2012 | 01:52 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Distributor Bolt Tool
Or you could buy a set of these:
http://www.harborfreight.com/7-piece...set-94426.html
Old Aug 13, 2012 | 09:29 AM
Engine: 350ci TPI
Those look like a useful tool. I looked at them online and thought they might round off the bolt head a little if it didnt sit just right.
Old Aug 13, 2012 | 10:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Or you could buy a distributor wrench.
Old Aug 13, 2012 | 10:26 AM
caditech's Avatar
Car: 83 Camaro
Engine: 383
Transmission: 5 speed
Axle/Gears: 4.11
lol or you can just use a box wrench
Old Aug 13, 2012 | 10:55 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
So you wasted 2 "extra" tools (no such thing as a extra tool & limited their future uses? Just buy the correct offset distributor tool. I haven't had to use mine in years but don't regret buying it.
http://www.sears.com/search=distribu...e=CAT_REC_PRED
Old Aug 13, 2012 | 11:04 AM
Engine: 350ci TPI
I did not know there was a distributor tool. Thanks for the info. I would have gotten one. As far as the "extras" go, the extension would'nt hold a socket on it if you turned them upside down. kinda frustrating working from the top side. I have a half dozen more cheap wrenches from bad christmas presents.
Old Aug 13, 2012 | 07:30 PM
rdsxfn524's Avatar
fer the crowsfoot tool ive found that to be useless unless your trying to break lose a stubborn tie rod end and u can put it on a breaker bar
Old Aug 13, 2012 | 08:28 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I vote for the distributor tool.
Frozer!!!
Jan 19, 2024 04:55 PM
Dkelz313
Apr 7, 2016 10:38 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 07:57 PM
383backinblack
Aug 15, 2015 06:36 PM
